need help modifying exausht system
sonic_darkknight
19
1,503
to all sifus here, need help and guidance, i'm on tight budget here, so i thought about two options myself on modifying the exausht pipe. my car is an iswara UK spec 1.5cc 4G15P with injection.
1) should i buy a zenden extractor and pair it up with my existing mid bullet and the rest of the piping remain standard?
2) or should i buy a second hand WISE edition whole piping from extractor to muffler, cut and weld back?
thanks for all the infos shared in advance.
drexchan
2,908
100
Bukit Jalil
drexchan.fotopic.net
the WiSE exhaust system comes with a catalytic converter. Your car doesn't need one. However, the piping will be too short for your car. To replace the missing past, you need either an extension or a bullet. A Cat. Con. Replacement (CCR) muffler/bullet might be helpful if you really want to go for the WiSE exhaust system.
this image shows where the CCR is supposed to go to: replacing the catalytic converter as its name indicated.
unknown1x
369
well.. sorry to use ur page , i have question to ask others... if u all can help, i driving iswara 4g13 carb, wondering.. if i change my exausht, to what size it will increase my performance or reduce fc? or.. remail stock best? since carb car generally don have ccr i think
drexchan
2,908
100
Bukit Jalil
No lar bro.. CCR means Cat. Con. Replacement. There's no cat con to be replaced in carbie.
Remain stock isn't a bad option too. Probably you can find the LMST exhaust system.
The Femme Fatale GT Party 2011 was recently held in Sepang F1 circuit, to coincide with the Super GT weekend. Levot Entertaiment was the host of the event and they brought in some famous names to entertain the crowd on the Saturday night (18th June 2011).
The...
