Need help for engine stalling evo3 engine!!
zero2hundred
1,225
6
earth
Hi sifus out there, pls enlightenme whats the problem with my engine lately, im using 4g63t evo 3 and im having bad engine stalling problem now, ive no problem when smooth crusing and boosting but the problem came when i off pedal and clutch release to neutral and brake engine seemed to stall and if lucky is rpm dropped to the lowest point and slowly climb back. When ive done at my side now is i took out IAC and replaced another and try and also my bov...both of these dont seem to have problem ..i also dunno whats wrong now..
zero2hundred
1,225
6
earth
i also thought of that bro....will have a check on hoses today i hope is only hose leakage problem if not this problem really give me headachea d..i expected the worst to happen :(
tauto
53
www.tauto.store
Good luck bro, I understand the frustration haha
hopefully its just a hose leakage
sweelt
Nov 6, 2016
2,306
248
663
suspect iac/isc or hose leaked.
Air-con ON during bad idle ?
And, do you compensate bad ilde by turning biss screw ?
zero2hundred
1,225
6
earth
i already replaced iac but doesnt seem a problem to it, had no problem with idling all gone pretty smooth even stand still or withh aircon on/off..the car will only went stalling when i was releasing acceleration and gear went neutral n start braking/stopping my car...for the hoses will check today..i just hope not anything related to electronic that will be very pening for me haha
sweelt
Nov 6, 2016
2,306
248
663
now i catch it. Maybe Brake servo leaked, happened to my 93t. Bad braking issue. and i notice big rpm drop but not stalling when press brake pedal.
i not sifu, but i base on observation only. :listen:
zero2hundred
1,225
6
earth
ok i will check my brake servo also but braking no problem all good..just brake and engine go stall..thx for the sharing bro..
zero2hundred
1,225
6
earth
yes...T_T...in this case the engine wont stall immediately just the rpm goes down very fast like going to stall..but i do noticed one thing when engine was cold everything seemed ok not until the engine fully warmed up and cruise until certain distance the problem come d..u can feel it more obvious...
zero2hundred
1,225
6
earth
Just want to clarify can be failure turbo actuator like actuator blockage when the gases no way out after boosting and returned which choked my engine and gone stalling ? Sifu pls enlighten me..is that possible? i got everything checked today like all the hoses and piping but no where leak...actuator is the last thing i havnt check..if its still not actuator problem my nightmare would be ecu d.. T_T
Greetings all! How are you?
I believe all the forumners here dreams or owns their own sport car. Its inevitable for us not dream to get own one. Same goes to me. I ever dream it since child where during my childhood, I used to live in the era of Evo 4-6, Mazda RX7, Skyline R32, R32, Silvia S14, Fairlady 300ZX, Mitsubishi FTO and GZTO and etc where I saw all these kind of sport cars in movies, car magazines and for sure on the road.
So, I make promise to myself that I gonna get this...
