need advice...gsr on evo gb or gsr gb?
guest
346
20
Kota Kinabalu
i do really need advice...im using auto gsr now and wan to convert manual gb...wat is the BEST! g.box for my gsr?gsr gbox ok?or evo ok?how about evo3 gb?some say evo3 gb not really perfect for gsr except for evo 1 n 2...so what is the pro and cons using evo gbox..and same also gsr gbox?help guys..
guest
346
20
Kota Kinabalu
whats the application? street normal use? highway? drag? circuit?
im somtimes drag also..so street use=35% highway =30% drag=35%...i saw my friend evo 2(4wd) loose to gsr...the said its because of the driving style and gsr have better ratio..is it true?i only wanna consider using evo and gsr gearbox..no for 1.6 mivec gb....any pro and cons on using evo gb?im asking this becoz i heard my of the gsrian using gb from evos....help..help
khoyos
2,632
156
5,163
Shah Alam
i used both gsr n evo gearbox on my gsr engine quite a while ago. gsr's 1st n 2nd gear feels stronger compared to evo gears on gsr engine, and evo's 3rd, 4th n 5th gear is simply awesome and unbeatable!
i noticed better fuel economy after changing to evo gearbox, better top speed as at 5th gear, the revs are lower compared to gsr gearbox...
so its up to u bro...
guest
346
20
Kota Kinabalu
ohh but i tot gsr 1,2 gear r lame...and 5th gear for evo are very high rev bcoz of its short ratio...110km more than 3.5rpm?evo 2 and 3 gb are the same?
Just reacently changed my Yrv turbine to Garret AR48, and there are powerloss because of insufficient fuel going to the engine. which is better, i was told that if i used fuel injectors i can tune it with my e-manage, and if i was to change fuel injector, what injector should i change to?
Fuel Regulator can make the fuel more rich to the engine? :confused:
