Naza Ria Engine transplant
jammiwong69
Nov 14, 2014
5
johor
Dear All,
Whoever is looking to transplant other model of engine to their car, please ensure your 1st choice workshop is capable enough to do so...
Jangan pandai cakap saja...
For me, I have to scrap my Naza due to neverending problems after converting...
I put almost RM30K to this converting project and finally it become a dust only....
What a shitttttt....
PLEASE BE CAREFUL IN CHOOSING THE WORKSHOP.....
Hi 3309
Scrap ur Naza??:banghead::banghead:
What happen after converting on ur naza??:confused::confused:
and is it the workshop first time convert to naza ria??
51
VQ25DE and VQ30DE are both v6 engines.. if you able to find VQ30DET that would be great...and coupled together with manual gb.. my mechanic has one lying in his workshop waiting to be transplant into his cefiro... for naza ria, he also done many conversions with VQ25DE/VQ30DE.. he mentioned as long as the engine mounting bracket fabricate nicely it should pass the inspection successfully...
May I know where is the workshop you convert the Naza Ria? Mine already convert to 6A13TT, but the foreman did not do a proper job.
Mitevo7
1,456
179
Shitttt .... now i am really appreciate the high costs i paid to my mechanic who did my E46 conversion.
ixeo
4,788
3,080
KL, Malaysia
which is why better buy something instead of modding it. UNLESS it is plug and play. Like a YRV Turbo onto a Kelisa/Kenari, where they just swap the subframe.
Mitevo7
1,456
179
Mine is totally not plug and play at all, i am fortunate all the cash well spent to make the car runs like normal. My next engine swap definitely is going to be plug and play. No more cross breed engine swap for me, at least in these few years time.
ixeo
4,788
3,080
KL, Malaysia
why not just buy the car that comes with the engine you want? Less hassle. That being said I highly recommend a Kelisa YRV Turbo. Plus it’s a straight swap. Only thing is the gearbox won’t survive if you mod the engine.
Mitevo7
1,456
179
Backside itchy, wanted to experience all the hardships of cross breeding transplant. Luckily it was a successful one, minus a few small issues.
alcyon
800
153
543
Because, its supposed to be cheap (er)....
Yup, you can iron out the problems immediately, rather than finding out later this is wrong, that is wrong.......
Mitevo7
1,456
179
As of now, i only kinda skeptical towards the E46 steering column looks very close to engine mounting. Am i suppose to worry ?
The Marketplace Top Posts
Guys, I have some problem, after some investigations:
- usually when temperature passes half, radiator fan will on and once the temp is slightly below half, it stops
- problem is, sometimes even after half, the fan is still not moving causing the temperature raised high (almost red bar)
- i thought the fan broken, tried to knock the motor (suggestion from a friend), still not working
- but, when I turn the AC on, both fans (radiator & AC) are on now. Meaning, my radiator fan is working! It...
