err.... fuel needle turun faster.... my wallet gets thinner....sky, got what improvement after change the cam?
>_<err.... fuel needle turun faster.... my wallet gets thinner....
still got what arr.... :hmmmm:
ooo... performance ar??... rev smoother n faster at higher rpm lor.... now sit 4 ppl in my car also still can feel some g-force.... jz now tried 3 ppl on board, 1st n 2nd gear acceleration, my car squat a little....>_<
I mean in term of performance la.. Not in term of wallet and mentally problem.
Nice.. the cam where you bought it ha? How much? I also want.. I see a SIOC member selling 292 degree regrind cam.. But he mentioned turn air cond then the car engine will shut off.. Why ar?ooo... performance ar??... rev smoother n faster at higher rpm lor.... now sit 4 ppl in my car also still can feel some g-force.... jz now tried 3 ppl on board, 1st n 2nd gear acceleration, my car squat a little....
consider satisfied kua, considering the budget i dump in... hahaha.... if i get branded ones, need around rm2k to siap pasang everything.... mine everything was under rm1k....
because the lift is too high mar.... at low revs/idle, air/fuel entering combustion chamber is not smooth.... and when firing is not available at certain stroke, engine loose power... thats why the higher degree the cam, the harder to idle at low rpm....Nice.. the cam where you bought it ha? How much? I also want.. I see a SIOC member selling 292 degree regrind cam.. But he mentioned turn air cond then the car engine will shut off.. Why ar?
errr.... u mean crankpulley arr??....Sifu Sky, wanna ask hor. The mythelogy cam pulley and Pipercam high degrees cam, considering both, which one will u choose? and why? I got acknowledged that cam pulley is better to be considered as the first modification than the high degrees cam. I've weighted the mythelogy , i would say it is lighter bout 30%-40%. Then, need to replace the 3 belts. If im not wrong, should be the thicker ones. Can teach ar , sifuuuuuuuuuu?
*sorry if i use wrong term.. really noob here..
thanks sifoo.....wah sky nice thread u got going on here!
correct me if wrong.... i pakai hantam only...
crankpulley is cheaper... less tuning required... jz plug n play...
camshaft is more expensive... need good tuner...
i would say mostly depend on u lor... camshaft powerband can be adjusted for top or mid range.... but LCP is usually for better pickup only....
as for other info, tofu sifoo answered u oledi lor...
thanks sifoo.....
nolar.... off a/c, idle at 800-900 rpm... on a/c, idle at 1k rpm (coz got a non-predictable FICD adi)... still headache with the FICD... coz sometimes it will stuck at 2k rpm idle.... need to switch off n on the aircond again only rpm drops to 1k rpm...:stupid:BTW sky.. what's the idling like bro..? 1200revs per min..? how bout air conditioning..? stable..?
u cant go wrong with a mythelogy crank pulley, i give 2 thumbs up but if others i dunno....bout the cam pulley, better get it with a street cam and install both one shot to save on tuning costs haha....Hey thanks to sifu-sifu tofu_manic , sky and tatayoung !!! A lot of info over there.. hehe :D
If just to improve drivability and not having instability of air conditioning or unexpected noise, should i just go for the crank pulley only? how bout the cam pulley? I'm trying to improve my car stability(chassis with strut bars), improve my pick up and having consistent accelerations and lastly, non-performance will be sound dampening. Need advice on the engine performance upgrades for 1.3 manual carb. Thanks.
kweng, what strut bar you taking? Why don't get fender bar? Fender bar work more in our car compare with strut bar itself. Get Fender bar, and rear strut bar then already improve alot.Hey thanks to sifu-sifu tofu_manic , sky and tatayoung !!! A lot of info over there.. hehe :D
Bro.. go for the crank pully and cam pully first.. if u're on a tight budget then the thai made one's should more than do the trick.. the cam pulley will help in the amplification of a certain powerband(of ur choice..) and the crank pulley is definitely gonna propell you to another level... that 'it feels light as hell' kinda thing is gonna hit you like 'Bham..!' chill... enjoy ya newly acquired additional power and if you still feel the need for more.. then by all means.. go ahead... but mind you.. aftermarket/lightened crank pulley's have been known to occasionally cause alternator issues.. weber's,highcams n so forth are 'proper' mods.. but they come at a cost and more often than not.. that cost is drivability... if it doesn't bother you then go ahead bro...Hey thanks to sifu-sifu tofu_manic , sky and tatayoung !!! A lot of info over there.. hehe :D
