mr2 engine swap
MK84
1,802
11
www.mk84.com
Actually fuel consumption with the V6 engine is lower. Depends on your driving style of course. Reason being, better torque means you don't have to rev as high before upshifts and can cruise under 3k rpm comfortably. Upsize the rear wheels and you can reduce the revs even more.
Weight wise if you get MZ series engine the weight is about same as a fully kitted 3S-GTE (ie engine + turbo + ancilarries). But they're expensive and with later models you have to deal with the drive-by-wire throttle.
The VZ series is cheaper but they're heavier (iron block vs alu block on MZ). On the plus side you get a standard cable-driven throttle, and thicker conrods.
The ultimate V6 to swap would be the new GR series engine. 280hp NA stock.... *sluurps*
koolspyda
2,889
55
KayEl
koolspyda.blogspot.com
yes yes 2GR FE (nice) & 1MZ FE
2GR-FE is raced on SuperGT (MR-S GT300) & on the new Lotus Evora.
3VZ-FE, 1MZ-FE, 3MZ-FE & 2GR-FE are some of the motors for midship.
MK is spot on on better torque with the 'bigger' CC engines. (envy)
too bad we arent as ballsy as some guys.:biggrin:
rex79gt
742
98
Ngiao City
ohaiyo minasan,
i;ve been doing my little research on mr2 engine
bcoz of the love to mr2 as it is one of my dream car
for engine, y not try using caldina;s 3s gte?
easier upgrading turbo for higher power as it is turbo charged engine
correct me if i'm wrong :P
KOYUKI
94
Caldina 3sgte cannot fit with SW20,the mounting is totally diff ler
if want u can try spend alot to modify it^^
tom's
2,865
76
subang
www.zerotohundred.com
why wanna do all the headache job and costly:hmmmm::hmmmm: unless u dun mind paying more and leave ur car in workshop let them R&D for you:rofl::rofl:........ easiest way get a mr2 halfcut or engine n dump it in.....
chlai28
71
Completely agree with TOM's !!! :adore:
rex79gt
742
98
Ngiao City
aiks
i tot same 3s engine so din take much into account -.-
oh well, maybe hav to change mounting, coz that engine pretty powerful rite?
turbo + vvti (dono got beams o not)
KOYUKI
94
Beams engine is a Dual VVTI system...1 control intake n 1 control output
is possible to have a turbo beam engine...like altezza 3sge beams oso alot turbo system on the road n quite powerfull
rex79gt
742
98
Ngiao City
but izzit true there;s only 1000units of beams engine been produced? -.-
i think this would b a very nice engine for my future MR2
tom's
2,865
76
subang
MR2 Beams engine is single vvti.......altezza is twin
Do you guys know where i can do rivet nut installation on the chassis? Planning to include more mounting points on the chassis for stiffening bars.
something like the link below
Pelican Technical Article: Installing the Lower Cross Brace on Your BMW
