Microtech
ftzone
full throttle zone
5,339
141
3,163
Penang, Prai
www.ftzoneracing.com
cold start settings not corrected... also most cars fitted with LT10s don't have a cold bypass air valve installed and hooked up. that is the problem.
In LT10s options menu you may want to tune for cold start.
(adj. only the temperature range that is giving you difficulty in cranking and warming up the engine from cold) Eg: 11deg C to 38deg the values should be smooth.
Screen 19 : PumpCold
Screen 20: WATER
Screen 22: CRANK
Screen 28: T Wat
Screen 30: Af_StE
I can't tell you the exact amount you need to configure as these settings and tests requires actual condition. However, some slight guess work could be done to improve the condition.
vteckiller
Supporting Merchants
1,606
34
Another year of drag racing events have just ended..and the microtech ecu has proven again CHAMPIONship of sepang drag battle overall winner for year 2010...
and broken the front wheel drive record with 10.6second (3runs in a row)at sepang drag battle..
microtech the champions choice...
congrats :) to those using the no1 ecu on planet earth!
---------- Post added at 01:48 AM ---------- 6 hour anti-bump limit - Previous post was at 01:43 AM ----------
LT10s the no1 ecu for 4cylinder....
LT16s the no1 ecu for 6or 8cyl.....
threepot
49
hi all microtech sifus,i wanna ask,can mt4 control ignition?as i know it cant,but on my frens car,it shows ignition setup on d lts handset(i1,i2,dwell etc2..)r this functional?thanx 4 any input...
chrissyong
975
14
did anyone experiencing fuel pump relay problem when relay running too hot ?
can explain properly is what kind problem? you mean after fuel pump run time too long fuel pressure drop?if wanna solve this kind problem need change your new wring from fuel tank to fuel pump relay
and bigger size wire~
EJ9
Mar 28, 2011
Shah Alam
Hi everyone...
As we all know...MICROTECH ECU has been no1 for the past few years in sepang drag battle now..from class B overall champ to class F non vtec and many other events winning non stop..
as part of microtech,we wanna once again congratulate all winners...and thanks for the support all the years...
We will be having a 1month offer for dealers and customers....even tho the australian currency is sky high...we will still maintain the old price to clients and dealers can benefit new dealership scheme...
contact us now!
those who wanna carry this no1 ecu ...can email or call us if interested...
regards
Joshua
Millennium Motorsport Asia
0123205454
0356334454
[email protected]
vteck: microtech apa u rekommend for civic saya? mine is EJ with K20A inside. long time tak jumpa, i come see u minggu depan becous my mekanik transplant ada wiring problem want do ecu kasi baik punya
vteckiller
1,606
34
ramadan offer...cash and carry and also with instalation.....
call today....
special offer rb lt16.....
---------- Post added at 12:01 PM ---------- 6 hour anti-bump limit - Previous post was at 12:00 PM ----------
u can visit microtechefi at facebook and click like...
---------- Post added at 12:32 PM ---------- 6 hour anti-bump limit - Previous post was at 12:01 PM ----------
Microtech Malaysia's no1 stand alone ECU............race proven....
jo1
392
25
3,028
miroctech the champion choice.....
AD_EG
6,000 RPM
6,328
231
Ipoh
my mech always say to be SAFE 1000km.
but i normally do it after 500km and *touch wood* so far all ok la.
vteckiller
1,606
34
Microtech no1 again at sepang drag battle best timing...
---------- Post added at 12:05 AM ---------- 6 hour anti-bump limit - Previous post was at 12:05 AM ----------
microtech no1 again at sepang drag battle best timing...
and latest info..
World no1 stand alone ecu..
The Marketplace Top Posts
'(00): You'd assume from the title what you'll be looking at would be a bastardized result of an in-breeding process gone wrong. But you'd be wrong. Think of it as a marriage of a potential 900KG hatch with the face of a legendary hot hatch and an engine on steroids.
