Dear All,
I bought my MS kit from DIY Autotune can some please verify if my car will be able to start? Is there already a base map in the microprocessor/chip?
Trying to contact cipan but to no avail so if anyone can forward me a phone number (or should Cipan see this message) pls do so.
Thanks.
There is no "base" map in the megasquirt when u buy it.
First you should make MS compatible with your engine. MS can work on all kinds of gasoline engines; so first u gotta see what ignition and fueling system are u gonna use.
Than u burn the newest code in your MS, and than u need to configure everything in your MegaTune software to work with your engine and all the sensors. Then u start making your first ignition and fuel maps...
Quite complicated if you don't understand the basics of your engine, electronics, fuel and ignition...
It would be best for you to contact Cipan, he can make all of this for you.
What engine do u plan on Megasquirting?
