kancil 882 Bolt On Turbo need help!!!
0339975
98
all sifus please help,
i just bolt on everything from mira on 850 block.the power is enormous but there's one problem.the con-rod bearing fails.it seems cannot with stand the compression made by the boost.FYI,im running with mira carburator piston+mira 12 valve head.compression is set high.wut i wanna know is there any heavy duty con-rod bearing for 850 crankshaft?any mira turbos con-rod bearings that is similar to 850 bearings?where can i get it?HELPPPPPPPP
The Marketplace Top Posts
URgent !!!! every member in ZTH please help , if u saw this white toyota alphard with WSQ 3334 please call 0111-6128628 (voltex)
SPEC
1.Aftermarket sportrim
2.without sun roof
3.interior brownish colour
