kancil 882 Bolt On Turbo need help!!!
0339975
98
all sifus please help,
i just bolt on everything from mira on 850 block.the power is enormous but there's one problem.the con-rod bearing fails.it seems cannot with stand the compression made by the boost.FYI,im running with mira carburator piston+mira 12 valve head.compression is set high.wut i wanna know is there any heavy duty con-rod bearing for 850 crankshaft?any mira turbos con-rod bearings that is similar to 850 bearings?where can i get it?HELPPPPPPPP
hi 2 all sifus!
quite sure this problem has been discussed b4 in the forums but lazy 2 search 4 it plus mine i'm sure a bit different perhaps??? anyways 2 sum it all up, my car's idling is VERY bad. cold start in morning impossible 2 start cos when i do, rpm will immediately fall after 2 or 3 seconds after car starts then engine mati. so i gotta start n press gas 4 awhile then idle stabilises somewhat... even when the engine dun mati rite the idle goes up n down around 500-1000rpm like tat...
