I want to talk about mivec engine
upboost
8
whose between u all can give me information about mivec engine?I have so many things to disscused.:driver:
---------- Post added at 02:12 PM ---------- Previous post was at 02:02 PM ----------
panjunkz
75
Ampang
I need opinion about mivec rs(1.6) vs mivec fto gpx(2.0).. Compare between those two engine. To fit in proton waja. Coz most people I knew still prefer the 1.6
Is because of maintainence? To owner who has use both engine may contribute here. A
Appreciate ur opinionm
Tq
P.s: want to do transplant but still unsure.
TopRpm
295
46
MIVEC FTO- 200hp
MIVEC 1.6-176hp
upboost
8
1st time joint forum.not really undrstnd to explore this forum facilities.just want to have more friend.
budakkampungaje
317
38
Dengkil
Tq
Mitsubishi FTO Grade GPX(my pren said the sound of MIVEC is like F1 betul keee?)
Displacement, cc 1998
Engine model 6A12
Max.power (Net), kw(PS)/rpm 200 ps (147.10 kw) / 7500 rpm
Max.torque(Net), N*m(kg*m)/rpm 20.4 kg*m (200.06 N*m) / 6000 rpm
Power density 5.85
Engine type V type 6 cylinder DOHC24 valve
Engine information MIVEC
Fuel system ECI-MULTI (electrically controlled gasoline injection)
Turbocharger No
Fuel type Unleaded premium gasoline
LEV system (Low emission vehicle) No
Compression ratio 10
Bore, mm 78.4
Stroke, mm 69
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 8.3
Fuel consumption at 60 km/h, l/100km
Mitsubishi Mirage Grade RS
Displacement, cc 1597
Engine model 4G92
Max.power (Net), kw(PS)/rpm 175 ps (128.71 kw) / 7500 rpm
Max.torque(Net), N*m(kg*m)/rpm 17.0 kg*m (166.71 N*m) / 7000 rpm
Power density 6.06
Engine type Serial 4 cylinder DOHC16 valve
Fuel system ECI multiple (electrically controlled gasoline injection)
Turbocharger No
Compression ratio 11
Bore, mm 81
Stroke, mm 77.5
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 7.1
MIVEC MD(MODULATION DISPLACEMENT)for saving fuel..Grade Cyborg [ MIVEC-MD ]
Engine model 4G92
Power density 6.06
Engine information MIVEC-MD
Turbocharger No
Bore, mm 81
Stroke, mm 77.5
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 6.2
MIVEC MD for 2.0 is only for ETERNA & GALANT(right timng belt)only......for F.T.O don't have....
Mitsubishi Galant Grade VX-R & Mitsubishi Eterna Grade Visage R(just for info):biggrin:
Engine model 6A12
Power density 6.35
Turbocharger No
Bore, mm 78.4
Stroke, mm 69
Final gear ratio
WTA, which combination of absorbers and sport springs would be best for street use? i know most of u would change to adjustables, but IMO i think that it wud be too hard for regular everyday use.
opinions?
:adore:
