How To Diy A Micro Compressor?
johnsonlam
DIY King
1,182
313
3,183
Balik Pulau, KL
First you DIY Money..
Then you Buy MicroCompressor loh.. :) hahah
I DIY PCV air Injectors.
Items :
- Home Cooking Gas Pipe
- T-Joint
- Air Controller Valve
- Small Air Filter (For Motor Bike / Breather)
- Cable Ties
Step :
- Locate PCV pipe
- Cut and add in T-Joint
- Extend the T-Join to Controller Valve
- Add Breather to the end of controller valve
- Cable tie tighly all the JOINTs
Tuning :
- Make sure all joints are tight.
- CLOSE the air controller valve
- Start engine (Idling Steady/Normal)
- Slowly open the valve..
- Engine starts to die.
- Tune it until the engine is stable again, at the same time got air suck in from the controller.
- DONE.
Forgot to add.. Drink 100 Plus..
NOTE : Mine, I replace the Air Breather with Whistle for 'Secret Mod'.. Thanks.
wetwetwater
462
Puchong
JL sifu.. can show more pics please ? thanks !!
P_driver
75
Johnson whats the theory behind this 'micro- compressor' thing. Quite curius about how it works. Thanks
speedking
880
to suck in more positive+ air and discharge negative- air for better combustion...i think
johnsonlam
DIY King
1,182
313
3,183
Balik Pulau, KL
Check out MicroCompressor website or re-seller..
They will give you BEST explanation.. HIgh and Low.
g88
3,081
54
Originally posted by WAJA2003@Apr 8 2004, 09:35 PM
That MicroCompressor website no work larr.
If wira 1.3 carb where is the vacum hose??
My friend did lasttime after seeing another of my friend car got . It's car Air Power. I think work the same as Air Compressor.
Original Air Power was sold at RM160 per piece. This only cost RM4 from kedai ikan :lol:
johnsonlam
DIY King
1,182
313
3,183
Balik Pulau, KL
PCV Valve..
It is on the right side if I am not wrong.
G88,
Yeah.. Your lagendary Air Power...
GOOD !!!
noir
5
JL, the whistling thingy for ur PCV, stim ar? Bunyi macam itu BOV ar?
johnsonlam
DIY King
1,182
313
3,183
Balik Pulau, KL
Ada lah sikit sikit.. :)
Siok shiok when changing gear, the pressure will reverse.. then can hear.. PPPSSsstt... (very soft)..
Angelz
333
haha u guys... i still dont quite understand how to DIY this thing..
what i need? =p
got so many tubes which looks like a vacumm..err.. which wan to connect..? and also err.. what is that thing? hehe... =p
Guys some dude cut line and whack my waja. By the looks in the pics
can someone tell me how much does it cost to fix the car?
Only bumper senget, 1 broken headlight and the bonnet abit bent.
Fenders are fine, although looks cacat but it's the reflection of the
tiang.
And most importantly, please recommend me a good place (good price,
good workmanship) in PJ area.
Thanks
