- Jun 4, 2006
- 2,798
- 334
- 1,683
Nope... if u get the same final compression pressure with the right A/F tunning, things should work fine. However, boost spiking is an issue to consider... IF, they spike...im not asking which is easier or safer or possible or more efficient or cheaper or whatever it is...
im asking why detonation tends to happened in medium boost high compression engine..
even the power output is somewhat less than high boost low compression engine...
The allowance for high compression engine is less compare to a low compression engine...
