haha ....thanks bro skywalker and renxun.
my next plan is change better drop in air filter 1st like KNN one. then the campulley ah, i still don know la ....i like the pick up and the same time i like top end torque also ....very hard.....(thinking of change engine to mivec lah....easier... sure got power one la. ...wakakaka)
yesterday, i try to do an experiment by myself. i took out the airfilter cover and just left the airfilter(the round white color) oli. and i tested from seremban(as i went to visit friend house at seremban) to kl. respond at 100km/h to 120km/h (RPM at 3500)is good la and can feel abit diff from stock.hehe .. but, i found out the FC also high oredi after i did this "openpod". why ah ?
and one more thing, like what bro renxun said, change to bigger pistons with stock engine block,will it spoil the block faster ah ? and my engine 1300cc and carb injection , can bore up to how many cc ?i mean maximum la ....
sorry bros, need advice and commend again. newbie ma.........hehe
change to k&n filter first la... after that retune ur carburetor afr... sure u can notice some difference... will result in better fuel consumption as well...
if u got the money, change mivec engine lo... prepare 10k for it...
fc high because u constantly playing with ur throttle revving it up... can say physcology lar... if u maintain ur throttle at constant level, i'm sure fc will decrease compare to previous... most important, retune ur afr regularly as carbie afr easy lari....
i've tested this method before... (diy open pod by removing the airbox)... vr good at mid to high speed... because less air restriction due to the small airbox... cruising at highspeed also result in lower rpm as less air restriction... as a result, melaka-ipoh trip can save me about quarter tank of fuel...
not recommended to bore ur 1.3 block la... best bang for buck is to find 1.5 block and bore it to fit bigger oversize pistons.... 1.5 block has thicker cylinder block wall compare to 1.3 block... hence, it can bore even more to fit even bigger oversize pistons...
Sorry to burst your bubble my friend, but what you felt was most probably psychological effect.. Or maybe just very very slight effect only at higher rpm because the air around wasnt restricted to your stock filter cover at high speed. But you're still using your stock filter.. Remember? Same size, same filtration.
The higher FC was most probably the result of your right foot testing out the 'new found power' and end up revving more than usual. :)
But if i'm wrong then, shoot away.
can i shoot??....
by removing the airbox, u are experiencing open-pod effect... hence, u are free from air restriction due to small airbox problem... standard airbox has a small opening at the end which measures 2.5" in diameter... how much air volume can pass thru it at high speed.... remember, the amount of air sucked by engine is alot at mid to high rpm... that small 2.5" lubang poses some air restriction when air needs to travel into the airbox into the carburetor...
