Custom an intercooler and make it your the size of your bonet. Then replace your bonet with it. Custom make your engine block and pistons with adementum (same as the material in wolverine's bones). Install another 8 550cc injectors. 3cm metal gaskets to keep it all in. Custom make your spark plug area to fit in another 4 plugs, meaning, you'll have 8 spark plugs. Use idirium magnesium hyperburnium plugs. Use super high performance plug cables measuring 2 cm in diameter for it's core. Custom make all manifolds (intake, exhaust, etc.) and all pipings with adementum. Install 4 tanks of NOS, each directly injected into the intake manifold directly. Use super fine high grade ultra performance terrorfied extra fully synthetic racing engine oil. Also remember to install 8 pot brakes for front and 6 pot brakes for rear. Roll on 20" spinners with LEDs on the spinners. Custom your car to have super wide body to fit in the 20" rollers. Gull wing doors which opens upwards and not the scissor style kind. Remove all backseats and install 4 units of 12" woofer tubes. Install enough amps to kick it. Custom make door panels to fit in 6 units of mid range on each door and rear side panel to fit in 4 units of 3 ways. Custom make boot panels to fit in 6 units of 8" woofers. Ensure all corners of cars are fitted with 2 units of tweeters each corner. Also, install enough amps to kick all those speakers. Then, go to Brothers and buy the RM368 JVC mp3 player and install it. Buy "rice led" christmas lights and line it all over the corners of the car. Since it's deeparaya now, you may want to consider hanging some electronically lighted ketupats and lampu pelita outside the car. Oh yeah, don't forget. Install flood lights under the car to be used as undercarriage neons. Oh yeah. Almost forgot. Make sure the exhaust tips are installed such that it comes out just before the rear tyres, near the back of the side skirts. Then, install firedragon.
Now, for the attention part. Open all windows and blast the frog song. Switch on all the lights installed in your car. For now, don't speed. Just drive along mamaks slowly and when you pass those mamaks which have tables and chairs at the road side, blast your firedragon exhaust at those people sitting there. Find a parking nearby or just park your car in front of the mamak, even if it's in the middle of the road. Then, get out of your car with 2 units of AK47s in hand and shout out, "HEY Y'ALL. WHAT'S UP?"
That ought to be one full package of attention and power.
