hello,
I have been driving Honda Sb3 with ZC engine for 14 years, i'm looking for power steering rack...........anyone can help
If u can find the civic wagon torsion bar would be more stiffer or you can mod the front civic eg coil springs and absorbers. However , the upper mounts (tapak) needs to be modified a bit to cater for sb3 body.SB3 front suspension using torsion bar rite??
where did you get the thicker/stiffer bars or u sumbat coil spring?
been trying to find solution for this ... i using 1st gen integra btw
Put back your termostat - replace your temperature sensor (at the bottom of your radiator-make sure it is new)....... it should be ok because I have this experience this before..............good luckok my turn to ask questions, chegu r u still with us or somewhere in the hondaowners club forum.my little sb3 have a very weird temperature problem (termostat was removed long time ago). Morning & afternoon use with/without aircond temperature below half (< 88 C), but if prolong use at night temperature shoots up way above half of the normal range. help anyone?? Battery voltage seems to be fine (above 14.50V with aircond & lights on).
Try already at halfcut......no luck............. Order from spare-part shop at Bagan, two time but after assemble .............. bocor, have to pay for workmanship .... rugi looshould be available at hafkat shop,... not on penang island,... butterworth and SP should hv bro,...
new one also bocor??? who fit for u? proton pomen kah??? lai lai lai, i rekomen pomen for u,...Try already at halfcut......no luck............. Order from spare-part shop at Bagan, two time but after assemble .............. bocor, have to pay for workmanship .... rugi loo
thanks bro.Put back your termostat - replace your temperature sensor (at the bottom of your radiator-make sure it is new)....... it should be ok because I have this experience this before..............good luck
whoaaa,... more wind resistance eh?Anybody who knows a shop to make this bodykit??
