Honda Sb3
Jul 2, 2008
hello,
I have been driving Honda Sb3 with ZC engine for 14 years, i'm looking for power steering rack...........anyone can help
fobs
3,752
hello,
should be available at hafkat shop,... not on penang island,... butterworth and SP should hv bro,...
harrycnut
28
SB3 front suspension using torsion bar rite??
where did you get the thicker/stiffer bars or u sumbat coil spring?
been trying to find solution for this :banghead:... i using 1st gen integra btw :listen:
sb3
1,141
14
5,138
If u can find the civic wagon torsion bar would be more stiffer or you can mod the front civic eg coil springs and absorbers. However , the upper mounts (tapak) needs to be modified a bit to cater for sb3 body.
sb3
1,141
14
5,138
ok my turn to ask questions, chegu r u still with us or somewhere in the hondaowners club forum.my little sb3 have a very weird temperature problem (termostat was removed long time ago). Morning & afternoon use with/without aircond temperature below half (< 88 C), but if prolong use at night temperature shoots up way above half of the normal range. help anyone?? Battery voltage seems to be fine (above 14.50V with aircond & lights on).
Jul 2, 2008
Put back your termostat - replace your temperature sensor (at the bottom of your radiator-make sure it is new)....... it should be ok because I have this experience this before..............good luck:driver:
Jul 2, 2008
Try already at halfcut......no luck............. Order from spare-part shop at Bagan, two time but after assemble .............. bocor, have to pay for workmanship .... rugi loo
fobs
3,752
new one also bocor??? who fit for u? proton pomen kah??? lai lai lai, i rekomen pomen for u,...
sb3
1,141
14
5,138
thanks bro.
, Hey u know wat , at times after driving for sometime my engine seems to be knocking (dunno whether detonation or pre-ignition : no good!) then i tried retarding the timing 2 degrees , whalah!! no more knocking & temperature problems!! Tell me its got nothing to do with timing.
sb3
1,141
14
5,138
halo!! anybody home???? sb3 owners !! speak up liven the atmosphere! sb4 owner are welcome also.
sb3
1,141
14
5,138
Anybody who knows a shop to make this bodykit??
fobs
3,752
sb3
1,141
14
5,138
Need SB3 front Bumper fast (at KL) help any one?
Congratulations go out to Yue Xian De, the recently announced winner of Geely's logo design contest. For creating the winning submission, Yue receives a Gold Medal, and two million Chinese Yuan (just shy of $270,000).
Yue beat out over 27,000 other submitters and earned the giant check, given to him in a presentation at the Beijing Geely University. While the logo should look a little better...
