- Dec 24, 2006
- 137
- 1
- 1,518
No k and n filter doesnt increase FC. Should have lowered it. Is it in an open box or in a cold airbox?? I realised that my old car use to burn rich with a filte rand that's bout it. Usually if u drive it nicely, u shud get more kmsI'm using K&N air filter (previous owner installed it), u think this will increase the FC? i think i have to look into the dirty injector issue.
By the way, my gearbox got little problem. When i slow down and cross over a bump then it is like free gear. The gear engage only when rpm reaches 2100rpm. Meaning first gear is not there but goes into 2nd gear at 2100rpm. Even this not happen all the time but it is frustrating me. May I know what went wrong? is the gearbox need to change already? pls help ...
U sound like you need a new gearbox too. It's auto right?? It might be the fact that 1st gear clutch is slippin coz auto gearboxes have like 5 clutches in them. One for each gear. Gearboxes can be expensive to fix. Might as well do a whole engine gearbox conversion and gearbox :)
You might also be getting higher consumption because the engine is worn out. The more kms u do on an engine, the more petrol u burn coz it wont burn as efficiently. The cheaper option is to buy an identical engine and gearbox if u dont have that much to spend on your car
