Help me ... clucth or gearbox ??
suru
58
6
Hi guys ... Im new with the car and new mmber here :wavey:
Got problem with gear .. bila rpm tinggi (5000rpm above) @ slps jalan jauh & sangkut dalam jalan jam (gearbox dh panas), problem ==> gear susah nk masuk ( dari 1 ke 2 dan 2 ke 3 ) ...
Pegi bengkel, diorang ckp clutch cover dh haus ... huuuurm, betul ke ?
So I think dah tiba masa to change my clutch kot ... any suggestions ? what brand & the price ?
One more thing, where I can get Spoon N1 muffler & the price ?
Thanks ... :adore:
subcon
1,442
49
Turn 5
a tells tale sign of your synchro starting to kong. try to change your gearbox oil first and see what happen
perhaps the others can explain more regarding this problem of yours
hasukyo
820
9
if gear oil doenst solve the problem, might be your clutch..i had the same problem too -_- until i change clutch
prasath_5338
1,131
19
Thanks ... :adore:
1) Change your gear oil asap. You can use Honda MTF 2 ultra.
2) If prob still there it must be your synro.:driver:
The Marketplace Top Posts
Since out side is so much of model for weber i not really understand for those weber.. just wan sum sharing here for let me know more .. bcoz i veli intereted in weber topic.. wats the diff DCOE DCFN i forget the name just tell me wat the diff between that.. and sum is twin weber some is single.. wat the diff also? for a 1.3 carbie.. is perfect suitable is which weber? after using the weber wat is the topspeed? and 0-100km/h? i really interesting in weber.. thxxx
