ford laser 94 1.5 overheating
doubleone_doublefive
9
putrajaya
hi and cheers to all,i'm a newbie in here.recently i got this one small problem wit my 94 laser,it's na 1.5l carb b5 engine and it's losing water.i've serviced the radiator,changed radiator cap,checked all hoses,waterjacket and all water lines,removed the thermostat,bleed the system.all fans are working and there is no water leaking.the engine temp still goes up if drive more than 120kmh.if maintain 80 - 100kmh temp maintain for sometime then it will go up.stop and check,water is missing.Could this be a gasket or head problem?please help.tq:banghead:
Nats autoparts
411
20
water pump got problem dy...
try change new water pump
do not run the engine if it overheat will destroy the gasket or engine !!
9
putrajaya
salam bros,looked into waterpump all is in working order.i think i should strip the head n do a top overhaul la.fed up already la.what u say?
Nats autoparts
411
20
did you open up the waterpump??
anyway if you did open up n check n yet nothing
that means your gasket giving way
proceed to that section then
pencalat
805
19
JB
do change water pump n if can do top overhaul...
9
putrajaya
salam bros...well ..sorry didn't log on for sometime,but did manage to strip the engine,semalam finish overhaulin the head,maybe today,later later at night i will start on the bottom part.all diy la bro thats why i didn't logged in.its a complete overhaul.if i can came up with the machining money by thursday,insyaallah the engine will be started on sunday morning.i will keep you all updated.by the way my loceng terbang no is 012 262 3473.can contact me also ma.thanks bros,you all been very supportive la..
9
putrajaya
The Marketplace Top Posts
Sant' Agata, Italy — With 2350 cars sold in 2007, Lamborghini is more successful than ever. But to stay at the top, one must continue to look ahead. Therefore, the company has taken the Murciélago LP640 to an all-new level and created the Reventón.
Named after a legendary fighting bull from 1943, this is the first car to be totally designed by the Centro Stile Lamborghini in Sant' Agata. And it is the first...
