FireStorm Ignition Coil Booster for more torque and fuel saving
peterlm
97
508
hi peter, can it be used on a V6 engine?
Yes, the FireStorm Booster can be used on all petrol engines. Please let me know what car model you are planning to install into.
Cheers.
---------- Post added at 05:09 PM ---------- 6 hour anti-bump limit - Previous post was at 05:08 PM ----------
wats the price?
Please let me know what car model you are installing into.
tonyops
249
17
518
Sarawak
Is it suitable for Corolla 4age 20V blacktop engine? PM me the price inclusive of shipping to Miri, Sarawak. Thanks!!
sirdex90
Jan 12, 2012
29
Labuan
Just Received and Plug In The Firestorm in My 4afe. Waited for months before i decided to try it. Thx alot to peter for being so kind as i asked alot.
-Idling rev reduced.
-Acceleration increase? (not much) but the acceleration lag reduced alot. Good when overtaking.
-fc? dunno yet
-engine sounds smoother
Nice Product and Seller!
peterlm
97
508
Thanks bro for your kind review. I'm glad you found the FireStorm useful.
Cheers.
-fc? dunno yet
---------- Post added at 11:54 AM ---------- 6 hour anti-bump limit - Previous post was at 11:53 AM ----------
Yes, the FireStorm Booster can be used in any petrol engine cars.
can use on any car?
RIZ63T
19
hai...can it be used for toyota caldina 2.0 N/A ... i'm just added Pivot ETC...
but i heard my fren said this will effect pistons and engine for long term...based on his experience... can u clear me ? i'm very intereset about this product...thanx
peterlm
97
508
Hi bro
Yes, I have many customers with the 1ZZ-FE and 1AZ-FSE Caldina and RAV4 using the FireStorm Booster in their engines without any problems.
The FireStorm Booster just provides stronger sparks to completely burn the air-fuel mixture that, in almost 99.9% of cars are not fully burnt. This is why we have the catalytic converter in most cars today. The catalytic converter's function is to completely burn up all unburnt gases. However, whatever gases that are burnt up in the catalytic converter is not providing any extra power to the engine.
The FireStorm Booster's stronger sparks will allow more complete burning of the unburnt air-fuel mixture in the cylinder so the result is that you can feel more power from your engine.
Your piston rings, piston heads and head gaskets will not be affected in any way since the efficient combustion does not lean out or enrich the air-fuel mixture. The FireStorm Booster does not increase the engine's temperature, unlike other ignition booster amplifiers.
Your friend's assumption on the long term failure will happen only if the air-fuel mixture is too lean. The engine's ECU is programmed to run a little rich so this is why the more complete combustion with the aid of the FireStorm Booster will give more power to the engine.
How long has your friend used the FireStorm Booster in his engine? You say that he is saying from his experience but is he referring to the FireStorm Booster or is he talking in general?
I hope that the explanation will help remove some of your doubts and also help your friend understand that his assumption is wrong.
Cheers.
Peter
hi all,
this is just me doing some good deeds here in ZTH by telling all you guys a good lesson, learnt from my experience just few mins ago, here it goes.....
went to check my engine oil 2 hours ago, heck guess what!! i was shocked to see the engine oil squirting all over the upper engine part, damn! i thought something is seriously wrong, until i removed the engine oil cap, and to my surprise i saw the bottom metal part was actually almost broken!! thankgoodness the bottom metal part...
