FD2R Clutch Pump
ylong
Jul 13, 2010
16
503
Hi all Sifu and Bro,
Anyone know where can i or any of the local garage whose know how to modify our stock fd2r clutch pump (Plastic) --> (Metal). Please share with me!!!
Because i had changed my clutch pump twice. And recently i had encounter such problem, When i clutched in, my clutch pedal got stuck at depressed position, At first i tot my clutch pedal stuck due to the carpet and when i stop aside and lift it up and then i tried to pump again and it felt empty @@
jaj_prakaash
63
1,508
Jurong
Don't know any local garage doing it but J's Garage of Singapore does modification on the stock clutch pump...
crtee
39
4
1,508
bro...what clutch r u using???aftermarket???or stock one??
dcloo
1,784
17
kl
bro the stock clutch pump already made by alloy body or its thats you means the tank ?
i dont think the tank made any clutch fail unless it crack or leaking only the pump will do the pedal flat
Dear bro, Can someone tell me how to modify this engine. it is tough because it is just SOCH Vtec instead of DOHC Vtec. moreover now i'm using singapore plate. what i can think of is to try on Port ad polish,UNIChip or E-manage piggy back,speed meter to check if there is speed cut or not. the rest, i do not know what to do anymore. i just feel that my current engine is so weird because on my 1st gear (auto), it can ram to oly 5500 only then change to second gear and can ram to only 6100++...
