Engine Oil Grade (meaning?)
netmatrix
2,255
42
P Jaya:Malaysia
kh_tan.tripod.com
You should change the filter the same time as you change the engine oil. Its cheap to change, and i do not see the problem to change it along with every oil change. Unless you are using very fancy RM100 oil filters, then i have nothing more to say.
netmatrix
2,255
42
P Jaya:Malaysia
kh_tan.tripod.com
Some oil filter allows flow inside it to be faster. This can be due to the materials used or design. Still you need to change them on schedule. I know of some guys, change oil 10000km and oil filter at 5000km. So you visit the workshop 2 times.
liquiddog
6
Guys i've been using Castrol GTX mineral 20W-50 for a very long time.
Then recently i saw a good deal for Mobile One, fully synthetic oil, i bought it and thought perhaps i could give it a try for my 13year old Wira. What do you guys think?
The main reason I'm trying this because I'm sick of the FC I'm having right now - 8.8km/l, approx 2.1cents per km for RON95. That hurts my pocket lol.
I really want to know if it helps, or perhaps worsen the condition of my car? By the way, my car hardly gives problems, pretty well maintained, just not too good in picking the right oil.
DanzEterna
15,911
3,371
www.primeperdanaclub.com
yup, carrefour had some promotions on mobil 1, but my foreman said, it might be
fully syn, but the grade is lower.....so thats y its cheaper.....
wats the recommended semi syn oil for my car? im not currently using motul 10w40, is it good enuf? v6 twin turbo.
huakenny
LB Performance
9,126
240
Kota Kinabalu
normal boost then ok, if hi boost then cannot
JINEIL2EN
15,317
525
Island Of Pearl
team99ers.2.forumer.com
huakenny,
tq bro...mine only at max 1bar...
Jin,
that 1 how much?
not sure... around 100 per liter kua...
pangyau
1,153
302
1,683
Malaysia
hi guys,
MOTUL product recommended by most tuner/mechanic/track user/daily user.
10W-40 (4100 Turbolight or 6100+ Synergie) suitable for daily user in town area.
also capable to boost up to 1.2-1.7BAR at 5-8K RPM tested by myself approximately 70km for awhile (few time only). as the theory to be use at 5,000km max
for 15W-50 (6100 Synergie) capable to handle high boost & little bit extra distance to gain.
but some say/experience little bit heavy for daily + town drive
At the moment 15W-50(300V Competition) are the best i ever tried for long distance (1,000km ++)
traveling + some speeding + boost 1.4-1.7BAR (shown on the DEFI). At 5,000km the lubricant still in good condition & make me satisfied.
MOTUL semi-synthetics series capable to handle up to 5,000km +/- 2,000km
but for 300V series (fully synthetics) capable to handle up to 8,000km +/- 2,000km
bottom of the line, life spent of the lubricant depends to the driver.
if drive like in track/racing + high RPM everyday, sure reduce the life spent.
P/S:
I used the after market K&N oil filter + magnetic sum nuts. to assure the quality.
learn from the experience people...
The Marketplace Top Posts
Hi! Sifu i managed to install my apexi rsm into my car! But My car wire link still running 1.6auto! But i change to manual gb now my apexi was able running the rpm but the speed it show 0 n not running! Later i sent my car to a accessories work shop but the guy say i was tapping correct n the charges me rm50 to check it but the end this guy say my this type car was running speed cable so they cant fix it! So sifu here can solve my problem where can i tap the speed wire the my apexi rsm...
