EM-Con M7 Piggy back ECU , 16 x 16 Fuel MAp , Additional parts : Ignition harness , Additional Injector Harness & Map Sensor . affortable price Sub-ECU .
M7 EM-Con is a cost effective programmable engine management system that allows you to properly tune your factory engine control without having to change the entire factory ECU system to an expensive "stand-alone" unit or the inconvenience of sending it out for a full ECU reprogram. The e-Manage system is a true universal "piggy-back" type unit that taps into most Japanese factory ECU wiring, by utilizing the vehicle’s existing sensors (or optional upgraded sensors if factory sensors are maxed out). The major benefit is the factory ECU settings become your "Base-MAP" for tuning.
