3 years on the Passat, the car is still in ok condition but just need some minor cleaning and correction, nothing major.
A Correction Detail [CD] the cars going for another 2-3 years of glossiness.
Combination of product used – Auto Finesse, Buff and Shine, Einszett and Polishangel
Dusted areas
Wheel is cleaned with Einszett - Colortec to dissolve brake dust and iron-rich contaminants upon contact
and wheels are fully washed
Auto Finesse - Avalanche Snow Foam is used to dissolve, loosen and carry away high proportion of dirt
and grime off the car in touchless fashion before washing in reducing the risk for paint marring
Dusted areas are cleaned with Auto Finesse - Citrus Power and Valet Pro - High quality detailing brush while waiting
for Avalanche to dwell
After the above processes is completed, Auto Finesse - Tar Remover a spirit-based tar and glue remover that quickly
and easily removes bonded organic contaminants from all exterior vehicle surfaces before laying our claying process
Before
After
Then we move to claying process as Auto Finesse – Clay Bar is used which is a fine grade, smooth textured clay
bar with Auto Finesse - Glide to further clean the paint which lessen the risk of inflicting surface marring
The whole car is polished with Einszett – Paint Polish using Krestel DAS 6 (DA polisher) with Buff and Shine 5.5”
compound pad to remove heavy swirl marks, hologram/buffer trails and fine scratches
Fine scratches
Fine scratches removed
The car is then rinse with water and the images below shows the fully polished paint results under the rinsing process
The rims is the protected by Auto Finesse – Mint rims wheel sealant while exterior trim is proteced with Auto Finesse – Revive trim gel
Auto Finesse – Ultra Glaze is used as first layer to dramatically enhance the gloss in order to create a dripping wet paint
and follows by Polishangel – Master Sealant (2 layers)
Dusted areas
Before
After
Fine scratches
