How about other aftermarket ECU such as Haltech, Apexi PFC & Motec (standalone type)?
Do we need to trim/alter/adjust the Fuel Trim (Short/Long) once awhile?
Even no other additional/modification done after the 1st tuning...
Seeking an advice & sorry for out off topic a bit...
Those are standalones.. you won't have any issues with it (with the right tuner).
Thanks ixeo for the good and clear explanation!! Is that also why ECU remap is equally as expensive as a piggyback setup?
I'm unclear about what you mean with "but once you remove battery and stock ECU loses the STFT & LTFT..then you'll be out of tune for sure", it doesn't mean that the stock ECU will lose it's settings (after a remap) if the battery is removed right?
I don't know how much ECU remap costs, but if that option is available it will always almost be better than piggybacks, as it makes full use of all available diagnostics and sensors that came with the car. sorry Toyota no remap for you
yes the stock ECU will lose its settings if battery is removed.
That's a bit worrying. So after I spend RM350 to tune, if the battery dies off I need to retune?
basically you gotta understand how STFT & LTFT works.. STFT makes real time changes based on the stock narrowband o2 sensor.. if its not stoich, the STFT will act immediately to keep it at stoich, in closed loop that is. when the changes done by STFT exceeds a certain limit as defined by the factory, it will store that change in the LTFT. in open loop ECU don't make changes based on o2 sensor anymore, it sprays fuel based on the factory map+LTFT.
usually if you did a tune after your ECU has settled down.. and the battery dies, the ECU would lose the settings. theoretically you should drive around with the piggyback unplugged until the ECU tunes its STFT and LTFT back and plug the piggyback back in.
easier way is get an OBD-II reader and check the STFT & LTFT.
I might be wrong by the way, after all I'm just a pirate with a boat.
