From the Pic i posted, you can see if without superlon wrapping the CAI pipe. There are small gabs around the pipe between the air box. So, after warpping the pipe with superlon and tigh it by cable tigh.Originally posted by drexchan@Mar 23 2005, 15:01
slk850,
how did you mount the hose to the airbox? Some superlon and double sided tape i assume?
beware of the heat.. i might drop-off when the heat melts the adhesive on the double sided tape..
[snapback]833946[/snapback]
Will it blocking air flow ? i mean with out the netting... air flow should be more faster ......rite ? correct me if i was wrong.... :POriginally posted by szekeiemme@Mar 23 2005, 19:55
the netting is kinda fine .. no insects can enter la..
[snapback]834872[/snapback]
what you mentioned is ram air.. no ram air doesn't work at the normal speed our car can travel. Air is incompressible at speed below the top speed.Originally posted by khguan@Mar 23 2005, 15:22
well.. if u install ur CAI hose in front of bumper... then de air going in will be faster cos it is forced into it.. when ur car moves.. then it create some higher pressure in ur airbox..
am i rite?
[snapback]834015[/snapback]
Those are not metal/alloy pipe, is made of plastic and rubber.Originally posted by jimmylkj@Mar 24 2005, 00:55
slk850 ... where you get those metal/alloy piping .... ? help me help me .... u c .. this evening i went to sunway n ask for those piping ... those fuckers either tell me no such thing else buy a whole new set come with the cover one ... sez wat housing not suits lar ... bla bla bla .... <_< .... soo ... can get for me ahh .... if the price is ok for me ... :P
[snapback]835395[/snapback]
