WTF, where you find such a damn big mosquito...
i not sure but i used dy in my power steering.:hmmmm:Can use power steering fluid for ATF then? Since is kinda vice versa for whoever said that
u change ur ATF filter before?:hmmmm:That's why, horizontal. Luckily my oil filter is located downwards. No messy job.
Kinda worried after the last ATF change. Saw so much metal shavings on the nut.
Haven't. U?i not sure but i used dy in my power steering.:hmmmm:
most probably need to change dy in next service.
---------- Post added at 06:38 AM ---------- 6 hour anti-bump limit - Previous post was at 06:36 AM ----------
not yet. dont dare to take the risk.Haven't. U?
ya.ATF filter, Much Bigger job....
Ya, Persona one is hard to reach. Idk about it but I heard from spareparts shop they say drop engine only change the filter, or else, they won't. Well, that is a mixed feelings.not yet. dont dare to take the risk.
some say persona using filter mesh.
Based on service manual, to reach the filter need to take down the AT gearbox down.
i saw on LYN persona, the filter picture is same like inside the manual.
Is proven inside gearbox got filter but i still not sure on the vertical pan area..:hmmmm:
ya.
If that is the case don't buy the filter yet we investigate by opening the panel and all firstYa, Persona one is hard to reach. Idk about it but I heard from spareparts shop they say drop engine only change the filter, or else, they won't. Well, that is a mixed feelings.
That bad ah! Others I see, they remove atf drain pan and can reach it already.Ya, Persona one is hard to reach. Idk about it but I heard from spareparts shop they say drop engine only change the filter, or else, they won't. Well, that is a mixed feelings.
WTF Nice!
Number 37 was the filter.
U can view the manual from this link.
http://www.mivec.co.nz/tech/F4A4x_AT_Manual.pdf
