can try with industrial grade cable ties. recently a friend of mine did on his ride. Seem to pretty much hold up to the abuse ever since!!
Not true la. If the brake hose is expanding even daily drive will benefit from itNormal use on daily drive don't need to tie loh......
If the hoses are expanding you need to replace them already.......Not true la. If the brake hose is expanding even daily drive will benefit from it
I think you mean brake hose not cable, anyway mine are already 25 years old and another car 20 years old and still using the original brake hoses....I believe if done properly it can even prolong the brake cable lifespan...
They don't make parts like they used to la Vr2I think you mean brake hose not cable, anyway mine are already 25 years old and another car 20 years old and still using the original brake hoses....
Yaloh! especially power window still running. If proton copy everything will be good , but want to cost down and fill many pocket, rakyat kena....They don't make parts like they used to la Vr2
If pop out, cable tie no good.....hhahahhahahmy diy cable tie brake hose is still doing well...none pop out. 4 years car
