Diy : Air Twister - Swirl The Air !
johnsonlam
DIY King
1,182
313
3,183
Balik Pulau, KL
Originally posted by Joeker+Sep 3 2004, 05:02 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Joeker @ Sep 3 2004, 05:02 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-johnsonlam@Sep 3 2004, 04:45 PM
I am not handsome
I seen JL before. Seriously, JL handsome like this pic. [/b][/quote]
:unsure:
Pengsan... :blink:
markhammill
7
Swansea, UK
www.metalstyli.com
I've got an ecotek valve fitted already that does a similar thing and creates turbulance in the airbox.
Is it worth adding a fan as well or would that be a waste of my ecotek valve?
khguan
4,818
26
Seri Kembangan
fotopic.net
well i dun think so... dat ecotek thing is soemthing like microcompressor... it let more air into de engine...
then de air twister we DIY is to spin de air while our engine suck in air...
markhammill
7
Swansea, UK
www.metalstyli.com
Oh well, I trimmed the fan ok but broke it putting it in, so that makes the decision for me :unsure:
gogsard
115
i have doubt to do this DIY .. afraid the fan will break lose into my throtel ..
khguan
4,818
26
Seri Kembangan
fotopic.net
dun worry bout de fan blades breaking... for my car.. i use 2 twisters... so far so good!!
when u install it.. just make sure dat they r fitted properly..not too tight n not too loose.. so dat it wun move.. use some double sided tape with foam to stick beside de blades to secure them....
-storm-
96
Hey guys i DIY this, keke sorry for bringing up old topics. Here is the pic!
When i first install this , which i dono installed correct or not,my car's induction sound (air sucking sound vroommmm)sounds louder, dono y, anyone care to explain? The car is more smoother now compare to last time, dono its physiological or what! Should i DIY a second one? if i do second one where should i put it? From the pictures u can see im using OEM air box wira efi!
ocphangaz
62
5
i DIY on using aircond blower fans... those squirel cage types.. i'm using K&N ufo type airfilter.
-storm-
96
SkYwAlKeR said:
i also diy one using cpu casing fan blades... so far, no positive response... hahaha.... wasted 5bucks for my casing fan....
Dono la my throttle response is better la. Can confrim that! :_:
NewVi
7
hi all...firstly all my compliments to JL for this DIY...very nice indeed :cyclops:
so now interested of getting one piece for myself....but i have a little question here about the location of the blades in my car...i drive a myvi 1.3....i have a diy cai with stock airbox....could anyone kindly shed me sum guidance on the location that the fan blades shud be install?...ie ... shud i install it at the opening of the CAI hose or elsewhere?
thx
-storm-
96
thx
Usually ppl install after the filter element! Check where is ur filter and install right after it! /good
wfhan
4,339
96
selangor
wow. 2 yrs topic still can bring up to discuss.. not bad. sweet!.
just to update, took out my 'air twister', not using it anymore,
considering the speed of the air flow going into the air ram,
i reckon it won't create a so call effective 'twist', but instead
it will create turbulence and mix the air (if that's what this diy item intend to do)
kob3bryant
484
i think the logic is the same as the design apply to center bullet.to make the air move faster
I have 1 nissan bluebird u11 in ori but I wanna to convert it to sr20det engine it is cost very high?or need to change many thing?pls gif some advise
