Consume engine oil
k0pi
105
28
528
Kota Bharu
Oil level was at dipstick bottom dot after 3000km. I jus poured in 1 liter and car feels more powerful and responsive compared to low oil level. Using 10-50
But after pour in 1 liter, I not yet check oil level. Next oil change, I got to buy 5L already.
Wonder oil consumption is due to high cams ?
May be one of the reason. I also after change cams have engine oil burnout issue despite has already fully overhauled the engine - at no common oil burnout symptom like usual (smoky exhaust, sludgy plug tip... signs of blown piston ring/scratched cylinder wall/leaky valve or plug seal).
But I did notice the engine oil decrease faster if I peak out RPM more often and gone long top speed runs, but level maintains if I drive in 'nerd' mode. The decrease can be noticed immediately after a night's hard drive. Sometimes I suspect the engine oil with little evaporation or tiny droplets sent flying under the head cover by moving parts, being sucked out from the cylinder head through the head cover breather ports (into intake plenum at higher rev & hotter condition) as logically, longer duration cams with higher valve lifts made higher vacuum flow into the combustion chamber at intake stroke along the peak powerband. Just my guess, but I rule out engine's leaking out the oil anywhere physically and visible. I would have noticed where it went.
The Marketplace Top Posts
Hey guys, I came across this grounding kit in a S'pore magazine yesterday, I though grounding is a "fake technology" how come a big brand like HKS can also produce a kit?
From reading on the web, I think its a HKS Japan product not USA, cause the Americans don't believe in grounding, or something like that.
Anyway, if this thing really works, would a cheaper brand like Pivot have a similar effect on a car?
http://www.fastwrx.com/hksceagrkit.html...
