i think he has a manual box, i have heard of people putting ATF in a manual box. i only gonna assume that was his intention but am unsure though. Btw gunner, is there any real gain from having a 3 stage vtec? im curious. i do apologize because i thought he was talking about stage 3 mods, lols. my bad.
From Wiki.....lol
3-Stage VTEC is a version that employs three different cam profiles to control intake valve timing and lift. Due to this version of VTEC being designed around a SOHC valve head, space was limited; so VTEC can modify only the opening and closing of the intake valves. The low-end fuel economy improvements of VTEC-E and the performance of conventional VTEC are combined in this application. From idle to 2500-3000 RPM, depending on load conditions, one intake valve fully opens while the other opens just slightly, enough to prevent pooling of fuel behind the valve, also called 12-valve mode. This 12 Valve mode results in swirl of the intake charge which increases combustion efficiency, resulting in improved low end torque and better fuel economy. At 3000-5400 RPM, depending on load, one of the VTEC solenoids engages, which causes the second valve to lock onto the first valve's camshaft lobe. Also called 16-valve mode, this method resembles a normal engine operating mode and improves the mid-range power curve. At 5500-7000 RPM, the second VTEC solenoid engages (both solenoids now engaged) so that both intake valves are using a middle, third camshaft lobe. The third lobe is tuned for high-performance and provides peak power at the top end of the RPM range.
In newer version of 3-Stage i-VTEC combined VTC and PGM-FI to allow ECU to control full range of mode to archive greater fuel economy improvements and performance. Honda CR-Z able to switch between low-end mode and standard mode from 1000 rpm to 2250 rpm uninterrupted and engage to high cam mode from 2250 rpm upward on SOHC.
