Hey guys
Any of you installed an OMORI Oil Temp Gauge ? Electric type not mechanical type
I have two wires coming out from the gauge ( remainder wires sorted the others )
-orange
-yellow
For orange I checked that it's flowing a 2.8v constant voltage
And it seem like this should be the wire that connects to the oil temp sensor/sender unit and supply power. But how does the meter pick up the reading after leaving the sensor since the sensor is a variable resistor that lowers resistance with increase of heat.
Yellow seems like a return line from the sensor but I'm not sure
The oil temp sensor is a Single Pin Sensor but I'm unsure how to get a reading on the gauge using the two wires orange and yellow.
If I supplied voltage(orange) to the top of the sensor and ground it with a seperate wire to the chassis the meter from the full 150c reading with warning light on will TURN OFF AND SHOW 50c WHICH IS THE START AND WITH HEAT IT DOES NOT MOVE
Please advice.
-orange
-yellow
Please advice.
