Cl7 cl8 cl9
sireuro
197
I see ... CRV K20A also got manual transmission...cool~
bien335
1,819
48
1,648
Johor Bahru
Wow!
never thought about the CRV
i know the Stream had a manual option, but was only available in UK.
awesome nonetheless.
amdfaisal
4,742
20
Bawah jembatan
it looks like JDM is not the ultimate reference lah... same like the accord type S. JDM only auto... in UK, US and even OZ, NZ got manual i think
sireuro
197
Saw a KL plate CL7 or 8 or 9 (dont know) on highway today ... white color ... the car is very high .. like CRV. Rims i think 17"
budakkampungaje
317
38
Dengkil
Yo ... anyone who know the question below .. please advice
I got a friend bought a Honda Accord CL8, at first I dont know what is the CL8, because I only know there are CL7 and CL9 in the market.
Need some experts to sort the specs below:-
CL7 got 2 specs:
CL7 normal: K20A 155ps (Automatic) Engine same as Local Civic 2.0?
0-100km/h : sec?
CL7 EURO R: K20A 220ps (Manual)
0-100km/h: sec?
CL9 I am not very Sure either 1 spec or 2 specs:-
CL9 Type S: K24A 200ps (Automatic) same as Odyssey Absolute Model
0-100km/h: sec?
And the CL8
- Now i know about the CL8, it is 4WD model ( horsepower? ) K20A or K24A?
0-100km/h: sec?
Thanks!
CL7 20e
Displacement, cc1998
Engine model K20A
Max.power (Net), kw(PS)/rpm155 ps (114.00 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm19.2 kg*m (188.29 N*m) / 4500 rpm
Power density8.84
Engine typeWater cooling serial 4 cylinder DOHC
Engine informationI-VTEC horizontal ranging chaindrive
Fuel systemElectrically controlled gasoline
injection system (HONDA PGM-FI)
TurbochargerNo
Fuel typeUnleaded regular gasoline
LEV system (Low emission vehicle)Yes
Compression ratio9.8
Bore, mm86
Stroke, mm86
Final gear ratio
Fuel consumption at 10-15 modes, l/100km7.2
CL7 euro R
Engine model K20A
Max.power (Net), kw(PS)/rpm220 ps (161.81 kw) / 8000 rpm
Max.torque(Net), N*m(kg*m)/rpm21.0 kg*m (205.94 N*m) / 6000 rpm
Power density6.32
Engine type Water cooling serial 4 cylinder DOHC
Engine informationHorizontal ranging chain drive
Fuel systemElectrically controlled gasoline injection system (HONDA PGM-FI)
TurbochargerNo
Fuel typeUnleaded premium gasoline
Compression ratio11.5
Bore, mm 86
Stroke, mm 86
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 8.4
CL8 20el 4wd
Engine modelK20A
Max.power (Net), kw(PS)/rpm152 ps (111.80 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm19.0 kg*m (186.33 N*m) / 4500 rpm
Power density9.61
TurbochargerNo
Bore, mm86
Stroke, mm86
Final gear ratio
Fuel consumption at 10-15 modes, l/100km7.4
CL9 24tl K24A
Displacement, cc2354
Engine modelK24A
Max.power (Net), kw(PS)/rpm200 ps (147.10 kw) / 6800 rpm
Max.torque(Net), N*m(kg*m)/rpm23.7 kg*m (232.42 N*m) / 4500 rpm
Power density7.15
TurbochargerNo
Compression ratio10.5
Bore, mm87
Stroke, mm99
Final gear ratio
Fuel consumption at 10-15 modes, l/100km8.3
jdm_jdm
121
16
Penang
CL7 got 2 specs:
CL7A : K20A 155ps (Automatic) Engine same as Local Civic 2.0
0-100km/h : 8.9sec
0-100km/h: 7.2sec
0-100km/h: 7.8sec
CL9 Type S: K24A 200ps (Manual 6 speeds)
0-100km/h: 7.5sec
And the CL8
- K20A 4WD model 155ps ( Same as CRV engine Spec)
0-100km/h: 12sec
The Marketplace Top Posts
car is going faster now that i have mod my entire exhaust system.
however, need it to stop in time too when i need it the most.
please advice on which section to modify 1st..
car - 2004 kia spectra 1.6 (a/t)
THANKS !!
