buying bmw e30
5115
Nobody
5,952
2,254
M52 should cost u more compare to M50.it has weight advantage since the block is made by aluminium
sakuragi,where u from?mind to join bimmer tt at TTDI to share ur experience?:wavey:
liauchinfoo
100
Hi 5115 and sakuragi,
Thanks for the input. I think before as what you think, M50B25 more power advantage than M52B25, and both sharing the same torque specification, but M52B25's power and torque happen at the lower rpm compare to M50B25, which I assume that it will have a better power band and torque curve, plus save a little bit patrol. Considering the weight of the M52 engine almost the same with M20 range, it will have better weight distribution compare to M50 engine. The less power of M52 engine is due to tighter emmision control with tigher air intake manifold, can be swap with the M50 air intake manifold with minor modification, and I believe it will gain more power.
Need to learn more about the security system or EWS on the M52 engine. If possible, use back all the electronics stuff into E30 (centre console with digital air-con individual control will be "cool"). Is it possible?
sakuragi
309
5115, I'm a bimmer newbie from Old Klang Road area. Would certainly find some time to join you guys for TT. However, that would be after CNY I guess. PM me then, cheers.
liau, M52/S52 conversion although less popular, it has been done many times in the states. But many would look into swapping OBDII for OBDI. But you can look up the following link for more info.
http://www.r3vlimited.com/board/forumdisplay.php?f=129
liauchinfoo
100
Hi sakuragi, many info from there and I learn a few from there too. Thanks and looking to see you soon.
The Marketplace Top Posts
Anyone knows where to repair carbon fiber in PJ/Subang/Shah Alam?? My CF spoiler is cracked...i think some idiot tried to steal it by ripping it out :(
its cracked at the seams... the part where the 2 pieces are joined together...so hopefully itll be an easy fix.
pic of my spoiler :
