better change absorber, springs and also bush because all these things cant last 10 years
for bush better change arm bush, spring bush, body bush
u will feel the difference
also check ur tyre pressure, not too high and not too low (31psi)(210kpa)
unless ur car is using leaf spring or torsion bar(for old car or 4wd car), it will last a little bit longer but also need to be change for quite time
and also ur tyre, if possible re-balancing ur tyre because unbalance tyre will cause the car to vibrate when driving and also bumpy ride
