Brembo Brake For MRS.
koolspyda
2,889
55
5,148
KayEl
koolspyda.blogspot.com
Re: Brembo Brek For MRS.
Efendi_njang
the master mr-s cylinder should be able to cope with 4 pot.
too large of brake kit in the front will interfere with the stock size mr-s rims.
you can get someone to fabricate the adapter but need to ensure the calipers can match the rotors.
Efendi_njang
86
508
not my car....my cousin car actually....he want to use brembo brek for his car....
now,he use 19" sport rim on his car....
hehehe.....
can anybody has use BBK for mr-s...dont mind wat brand,s long s,good quality......
thx for reply......
koolspyda
2,889
55
5,148
KayEl
there is a Lotus 4 pot front brake & easily adaptable without changing/custom a the bigger brake pump (which if not dont correctly may leak or worse case senario car is worse off) by one of mr-s owners.
i'm having a original brembo 4 pot with rotors in my car. (not customed) & was discontinued by brembo as many felt its too expensive & stock brakes seem to be able to cope with it.
of course & unless you ride has been slapped with alot more powwer,......:driver:
hi ZTH members , need some help regarding modifications on my peugeot 206 1.6 16v AUTOMATIC transmission
current mod is :
1)4-2-1 extractor (custom by JFA based on peugeot sport setting, removed cat)
2)k & n typhoon air intake (long ram type)
3)topcat muffler s flow, piping 1.6 mid and 1.6 end ( all done at everco n really satisfied with it)
4)denso iridium spark plugs
dyno chart shows 122 hp @ 5.5k rpm and 164.4 Nm / 110 ft.lb / 15.2 kgm @ 4000 rpm , power to weight ratio at...
