There are a few contribution to the loud sound(which i call it noise). U can:-Taiko...I got one question long time wanna ask you...
Hmm...Bigger turbo will cause the exhaust louder ??!!
Coz I saw those evo , subaru , supra ..etc.. when they start engine..the exhaust sound LOUD & NICE !! Any advice ??
Coz I plan to install Bigger turbo..hope my exhaust sound like 'em
Not necessary. Bigger inlet diameter to be precise...wanna louder sound .. change bigger muffler lo...
Taiko...Actually I am using Trust PE II...inlet 3"...and I using straight flow also...2.5"....There are a few contribution to the loud sound(which i call it noise). U can:-
Change to bigger exhaust diameter.
Change to higher lift and duration cams
Throw the mid box of your exhaust
Straight flow exhaust muffler
Tighten the throttle cable
Inchrease the iddling RPM, sound more aggresive.. kekeke
Since u read about overseaforums and threads.... Get to know what thaey are using... Thigns should work fine.did anyone here try to BOT on NISSAN SENTRA N16?
I feel the car is heavy and does not want to perform engine convertion.
Therefore, BOT is the choice~
I saw from overseas forum that PPL doing that. but does anyone tried b4?
Is it successful doing that?
I suggest go for stage 1 bolt on turbo... means..get a intercooler ,turbo(TD05)..etc...and boost 0.5bar..you will feel the power Dont worry bro..as long as dont overboost.....wont kill your engine..did anyone here try to BOT on NISSAN SENTRA N16?
want sound only rite? put relay lorLast time I check out.. I have a FAKE Walbro !! the sound very loud ..can heard from outside.. when engine starting ...now i change another once...
Normally after install walbro fuel pump ...got the sound yieeeeee~~ right? like nyamuk sound....
Coz I install this walbro fuel pump + fuel return line......but dont have the sound ??? why ?!
anyone can help me ? coz i love the sound.......
is it normal ?? a bit sound only....
Ngeeeeaaa..... that should be the sound. Should be able to hear from outside. If u want even louder, instal an external pump lor...Last time I check out.. I have a FAKE Walbro !! the sound very loud ..can heard from outside.. when engine starting ...now i change another once...
Taiko. have to understand the characteristic first before BOTing la. U want ppl engine to detonate kah...? Try do that on a B18C. I guaranty engine knocks when turbo spools... Tested.I suggest go for stage 1 bolt on turbo... means..get a intercooler ,turbo(TD05)..etc...and boost 0.5bar..you will feel the power Dont worry bro..as long as dont overboost.....wont kill your engine..
Bro, i suggest u to understand ur engine characteristic as in Bore n stroke, Compression ratio, block material. If possible the cylinder top volume and availability of aftermarket product in support of ur project in our market.did anyone here try to BOT on NISSAN SENTRA N16?
u r rite~Ngeeeeaaa..... that should be the sound. Should be able to hear from outside. If u want even louder, instal an external pump lor...
A good setup isn;t just on the hardware and how much u boost. It should comes along with software too... In this case, tunning.
then u can decide if u wanna continur with your BOT. Lot of ppl buy stuff buy stuff and ended up selling everything because project suspended for too long due to overspent time searching for parts.
I can't even heard the sound ngeeeee.........is it install fuel return line...then can't heard it already ?Ngeeeeaaa..... that should be the sound. Should be able to hear from outside. If u want even louder, instal an external pump lor...
U sound like jut me only... >.<u r rite~
Erm... why do u need to install a fuel return line when ur car already has a fuel return line...? Can an engine work without fuel return line kah..? kaka... U do ur car in kuchai lama..?I can't even heard the sound ngeeeee.........is it install fuel return line...then can't heard it already ?
i also can't even heard from outside... when my car left 1 bar which the petro going to habis..also can;t heard the sound.......why ar ?? juznow i start my car...then i put my eat under my car there also can't...heard a bit bit nyeeeeee only...but dont know is my ear problem or...........
ya..do at kuchai lama..you know i know..:rolleyes:U sound like jut me only... >.<
OK... the sound comes from the pump. When u take out the pump and tap it to battery also damn 7 loud already. left 1 bar petrol no sound..? got experience not enough fuel and cause engine jerk or stall due to insufficient fuel in the tank even though the indicator tells u there are still fuel in the tank..? cause walbro is shorter by a little.
