Bolt on turbo problem:
lumps1985
13
Just want to know why is my exhaust keep on coming out black smoke after
install a bolt on turbo kits on my kelisa auto (year 2000)
Issit B'cause of:
-fuel too much
-spark plug problem
-turbine problem
Kindly please guide me some tips to solve this problem.
thank u very much....:adore::biggrin:
ehdrian
I Don't Care!
3,310
280
1,683
do u install any piggy back on ur car?..black smoke is usually cause by afr too rich..
lumps1985
13
Thanks....ny the way i did't install any piggy back on my car,(too expensive),is there any other way which is more cheaper.a cheapest piggy back cost me bout a Rm950 for a ECU board.Such as fuel regulator or any DIY stuff which u can recommend???I'm base in Klang area....:confused:
speed2horizon
2,798
334
1,683
Well, turbine problem has got nothing to do with black smoke... When turbine have problem, it's either boost inconsistency of white smoke due to leakage...
When black smoke appear, it's due to rich AFR. Mind describing more about the black smoke... When does the black smoke appeared..? Even at idling or when boosting...?
lumps1985
13
in idling and when boosting also will have some(mayb is the left in the piping GUA).If is the fuel problem issit i need a fuel regulator??? and what brand will u recommend but must be the good and value for $$$ lah:proud::proud::proud:.
Bump: in idling and when boosting also will have some(mayb is the left in the piping GUA).If is the fuel problem issit i need a fuel regulator??? and what brand will u recommend but must be the good and value for $$$ lah:proud::proud::proud:.
veilsideboyz
1,616
17
i have a piggy wanna let go..RM1000...dynojet PCIII...
interest pm me...
badturz
580
hey bro. i also got 1 of my frd using auto and BOT .. he using safc only .. 450 he got it in zerotohundred marketplace.. boost 0.5 not mistaken .. the black smoke come out from his car is when he release the acceleration pedal. he been bot into his kelisa for 4 months edi .. so far so good.. :driver:
Bump: hey bro. i also got 1 of my frd using auto and BOT .. he using safc only .. 450 he got it in zerotohundred marketplace.. boost 0.5 not mistaken .. the black smoke come out from his car is when he release the acceleration pedal. he been bot into his kelisa for 4 months edi .. so far so good.. :driver:
speed2horizon
2,798
334
1,683
well... When u select a piggyback, 1st thing to consider is wether or not it supports ur DVVT. Safc is ok.
Tell us what u've done on your set up before any justification made.
lumps1985
13
is true but i've seen many forum nobody want to sell SAFC II,i want to find one lah bro...anybody want to let go??? budget Rm750:biggrin::biggrin::biggrin:
It seems like forever and some more since English automakers Arash first let slip on the plans for their supercar, the AF-10. While it might seem dead in the water, but finally after five years of research and development, the car has been put through a 3D modeling program in the crawl towards final production...
