Originally posted by lilvee@Feb 22 2005, 10:08
Act, i'm in a quest to boost my d16. I got my e-manage oledi. The rest, need to survey la..
Bro.. do u mind to list down ur kit that u had installed there?
1. Turbine (brand/recond/new/ballbaring/etc..)
2. Wastegate (with/out/inter/external/down pipe...)
3. Intercooler (using fan?/on all d time?)
4. Injector (replacement/additional/
5. Engine Oil cooler (is any?)
6. Blow-off valve (psssshh... sounds cool)
7. Boost controller (manual/electronic... safety 1'st maa)
8. etc....
9.....
Hi bro ,
ok let list down the details of the turbo kit :
1. Turbine (TD-05H or our hybrid ball bearing turbo) both in recon condition.
2. Both turbine using back original internal wastegate , s/steel custom made downpipe.
3. Intercooler = if you are using front mount intercooler , no need to use fan. if you mount it at the side for hidden , then you need to use fan in ALL THE TIME.
4. Injector = remain the four original injector , additional 2 pcs bigger cc for turbo use.
5. Engine oil cooler = if have it will be must more better , but not easy to find cause we need a adaptor . Even if chop shop have they sell very expensive.
6. Blow-off valve = must have la , just using normal 1 enough already.
7. Boost controller = depends , standard boosting 0.7 - 0.8bar.
8. e-manage = MUST HAVE COMPLETE WIRING , INJECTOR AND IGNITION HARDNESS , OTHER WISE CAN'T HELP !!!!
9. turbo timer and boost meter.
10. 2.5" exhaust
