stopid9 said:
guys,
how do you tell if the ayc or acd is spoilt or something wrong?? and the ayc pump ??
how do you know??
is ur ACD 3 lights at the dashboard all light up? if not should be no problem. bear in mind, there must be 1 yellow light on at any time, but not ALL 3. if totally no lights...then i suspect someone took out the bulbs or short out the lights. if this is the case, then they maybe trying to hide the AYC/ACD problem from u....be careful.
plus when u corner, do u hear any sound from your right side end? this is because the AYC pump is located there for evo 7 onwards. for evo 6 i am not sure.
some ppl say got sound when they corner...maybe some metal particles due to wear n tear inside, so need to flush out.....do this by flushing out the ayc oil. should come out.
ayc is a mechanical thing...is actually very hardy. ACD is a whole she bang system with ECU n stuffs should be okay as well.
as long as u dun hear any funny noises..should be fine.
