Dude, i just say that I AM TOTALLY CONFIOUS ABOUT THE RESULT TOO!!.. that mean i also shock with the result..And again that not only what FPR use for... 1 more thing, "belaja tanpa guru akan membuatkan anda sesat"(forgot the actual statment for this) so basically learning using only Mr. Google dosnt approve that you good enough.. If that's how easy to learn, then there will be no university and totally no teacher..plus we can even get degree from internet..ye...
mungkin betul...
namun hati-hati tune afpr tu jgn smpai injektor stock u cepat defect...
cube la study/google sikit afpr ni, lebih sesuai utk mod kategori turbo ke, supercharge ke, NA ke...
dengan mod pd kadar kos rm300-rm500 hingga naik 7-8 brake horse power, logiknya dah tentu pembuat kereta dah pasang siap-siap pd kerete mereka...
guna high-lift cam (billet) bukan high-cam ( yg re-grind lebih utk duration jer)+piggiback ecu pd NA berkos rm3.5-4k pun hasilnya ciput aje...
namun apa-apa pilihan/keputusan ditangan empunya keter...
em...Dude, i just say that I AM TOTALLY CONFIOUS ABOUT THE RESULT TOO!!.. that mean i also shock with the result..And again that not only what FPR use for... 1 more thing, "belaja tanpa guru akan membuatkan anda sesat"(forgot the actual statment for this) so basically learning using only Mr. Google dosnt approve that you good enough.. If that's how easy to learn, then there will be no university and totally no teacher..plus we can even get degree from internet..
PS: telling again, i am totally confius too because of the mod that been done i get that result..
owh btw that's not the only mod i have done actually...
BTW i never see any dyno or good result for that so call as billet cam..regrind was better, unless there is prove (only applied for sp4h billet cam from w*** eng***). There one person already made documentation about that cam, and the result.. totally ****
peace and im out~
i've tested both, 20 horsepower differences.. dynojet --> big single roller --> inertia / dyno dynamics --> smaller dual roller --> loadwhats the diff between dyno dynamic & dyno jet..?
low 13-s / or high 12-s is ideal already :)14.10 to 14.20 AFR on full load, is it dangerous??
yup, infact it is ( dangerous ). having a weak mixture could cause premature engine failure or worse..mine was all above 14.0 when dyno. one the jc guy suggest me to install fuel regulator cause he said it is dangerous. is it true?
mod: just upgrade to r3 cam.
Similar threads | Forum | |
fuel gauge? | Satria Neo Forums | |
fuel light | Satria Neo Forums |
Similar Threads | ||
