Anyone good in electronics/car wiring?
ambayah
1,323
Guys,
I am trying to make a switch so that when turned off, theres no way anyone could start the car. Can someone point me where such swith/wiring should be placed?
I heard that there is ignition disconnect which prevents the engine from running but I have no idea how to do.
Driving Proton Satria 1.3 GLi
Thanks.
rasco
55
shah alam/JB
comp.fsksm.utm.my
i'm not good in eiring but i got a simple idea..
how bout u just cut the wire that lead to 'ON' state put switch between it..
so... that wayeven if u turn the key to 'ON' state.. it won't start when u crank it.
or.. just put d switch between the +ve terminal. :lol:
-just a piece of my mind-
ambayah
1,323
or.. just put d switch between the +ve terminal. <!--emo&:lol:--><img src='style_emoticons/default/laugh.gif' border='0' style='vertical-align:middle'
alt='laugh.gif' /><!--endemo-->
[snapback]874529[/snapback]​
I asked people say thats not effective, they say bad people can still beat that. <_<
Maxx
2,072
42
5,148
PD-Putrajaya-KL
www.zerotohundred.com
if u cut the wiring to ON position u'll need relay, coz that wiring is high amperage.
cutting starter wiring also can be used but still need relay..
simple way is, disconnect ignition wiring that goes to distrubutor and put switch. bwt, the engine still can be crank but cannot be start coz no spark from spark plug.
rasco
55
shah alam/JB
comp.fsksm.utm.my
just a suggestion :lol:
maybe can put valve on ur fuel pipe :D like bikes (RXZ/NSR 150)
use switch to control the servo that open/close ur fuel pipe. engine can be start for a while only. :rolleyes:
ambayah
1,323
I found a blue socket on top of the dist. which one is you think ignites from the switch?
trex92
756
5,018
Originally posted by ambayah@Apr 6 2005, 20:11
Guys,
Thanks.
[snapback]874461[/snapback]​
Yup, i added one for my car. I presume urs is a Proton too. Open up the housing for the steering (held by 2 or 3 screws from the bottom of the steering housing, look at where the lever to adjust the steering is). Unscrew them and after that open the housing.
After opening, u would be able to have a open access to the ignition key. Unplug the wire harness for the ignition key. Have a good look at it. The thickest wire is the + terminal. The other 3 small ones are:-
1. For radio etc
2. For main power to the car (meter console, Check Engine, fuel pump,air con etc)
3. For starter motor for ignition
When u turn the key in ur ignition, the wire harness acts as a switch and it goes in step. The first step it connects the + terminal to (1) above, there's where u get the radio. When u turn the key further, it connects + to (1) and (2), that's where u get the check engine light. And when u turn further some more, ur engine cranks.
You have 2 choices to add in the switch. Firstly, you can just cut the connection for (3) and put a switch in between. When u add the switch here, you can power on the car, the radio, air con blower etc with even the Check Engine light. But when u turn the key to crank the engine, nothing happens. This method is good to confuse unauthorised users as they would not think it is due to a switch but rather a bad battery or something. But this method is bad because when u can power up the car, you can reset the car alarm (presuming its someone without using the key to access).
Or alternatively, you can do like i did, you can cut the + terminal and put the switch here. When u put the switch here, nothing happens when the key is turned. No radio, no Check Engine light, nothing. Even when u press the alarm reset button also nothing happens. Car would be totally dead.
The process is quite easy. Just cut the connection and add in the switch, or after cutting the connection, you can add in wires to lengthen the connection and hide the switch further away from the driver side. Use a good 12V switch and good wires. For the wires, I would suggest u use the same wires that are used to power amplifiers (thick red ones).
rasco
55
shah alam/JB
comp.fsksm.utm.my
is a relay required??
hehe.. this is kinda cool..
add a push start button or a flick start switch... and u get more switch to play b4 starting the engine...
sum ppl will sure b impress.. but sum will say.. "troublesum" :lol:
but the idea is cool..
ambayah
1,323
Yeah, is relay required, I asked Maxx, he said require, can you like draw the diagram fo a relay, or got tutorial to put relay? Please.
trex92
756
5,018
No, a relay is not required, I am running my switch with no relays and been running for 3 years now with no problems. It does not make sense to add a relay as originally, to complete the circuit, Proton also dun have a relay so how come u need to add one in now, right?
If you still want to add a relay, please refer back to some of the old postings which talked about how to wire relays. Got some diagrams and stuff.
The Marketplace Top Posts
Video: New 1500whp tuning package by Underground Racing for Gallardo Superleggera
Underground Racing has produced some pretty extraordinary tuning packages for the Lamborghini Gallardo's but this is probably their wildest yet - a...
