My Evo 8 equipped with 6 speeds. But the problem is Hard to turn to reverse gear every time. Sometimes I even need to put hard with my right hand. Any Sifu know what is goin wrong ???
Clutch pedal may require adjustment. A few minute jobby. Not uncommon after installing a new clutch or normal clutch wear. Try this 'free' stuff first, don't buy expensive oil or clutch yet.
for me that is normal a little bit hard to go for the reverse gear expecially when juz started the engine n directly want to put the gear to reverse..so now what i did was let the engine run for a while then easily change the gear juz using my left hand. that is my experience laa..dun no urs same with me or not??he..
anyone know how to make the light inside ur car dim slowly??as in when u off it or close the door the light slowly fades away and not suddenly jus switch off.....any idea??
