Any member drives Frontiers ??
gavan
1,408
Shah Alam
aiyah, ulu slim no need hardcore wan ler, my stock car masuk few times already, with HT samor... haha... i trying to call nighthunter go along together gether... so far all my trips all go with him wan ma... hehe... =)
traize
519
5
oh i see, u guys stay there or not?
TitanRev
You think I print money?
8,180
3,678
Gavan, sorry for the late reply. Yes, mine is steel rim. I'm using 245. I think that's the widest the steel rim can go. 245 above will need to use sport rims to fully utilize the tires performance.
gavan
1,408
Shah Alam
well, most likely it would be after CNY la... =) yeah, should be staying over a night there... its a cool place, next to river only, confirm sejuk wan, went for a one day truip there before and it rained... got mist ooo... imagine... =) hee hee heee...
Bump: well, most likely it would be after CNY la... =) yeah, should be staying over a night there... its a cool place, next to river only, confirm sejuk wan, went for a one day truip there before and it rained... got mist ooo... imagine... =) hee hee heee...
owh, so i guess the u7jj rims shoudl be no problem fitting anything bigger than 245 la since the stock also comes with 245 already. the new navara comes with 255 or 265 tires i believe... nice ooo... =)
traize
519
5
265 coz same as my pajero, but i think want to put 33inch MT tyre as soon as my old 1 botak
gavan
1,408
Shah Alam
yeah, same here, need to change my tires soon, just contemplating MT's or AT's only... sigh... and i need some offsets also...sigh...
and i dunno wether the wider tire would give it a wider stance anot... hmm...
gavan
1,408
Shah Alam
What makes a 4WD a 4WD?
Four wheel drive vehicles come in all shapes, sizes and body styles with different types of features and equipment. However, there are several basic functions that all 4WDrives have in common.
Drivetrain
A 4WD can be a constant 4WD, part-time 4WD or both. An example of a constant 4WD is a Range Rover. It is always in 4WD and cannot select 2WD at all. A Toyota Tacoma is an example of a part-time 4WD, which means that it can switch between 2WD and 4WD.
A Mitsubishi Pajero is an example of a 4WD that can be both a constant 4WD and a part-time 4WD. It can select 2WD, constant 4WD and locked 4WD. The difference between the Patrol and the Pajero is that the Pajero has a center differential. A center differential allows 4WD to be used on normal roads (constant 4WD) and can be locked for off-road use (part-time 4WD). The "axle/transmission windup" text below explains why a part-time 4WD cannot be driven in 4WD on the bitumen.
Axle/Transmission Windup
When a 4WD is traveling in a straight line all four wheels rotate at the same speed, but during cornering each wheel travels at a different speed due to the radius of the turn. All vehicles have a differential on the front and rear axles to allow the wheels on the same axle to rotate at a different speed. Constant 4WD’s have a central differential fitted to allow for different speeds between front and back wheels, but most part-time four wheel drives do not.
When a part-time 4WD (without a center differential) is in 4WD an attempts to corner on bitumen, all wheels need to rotate at different speeds, but without a centre differential they cannot. This creates the phenomena called "axle windup" or "transmission windup". High strain is placed on the drive shafts and transmission, eventually causing one of two things to happen. Either one of the wheels slips or spins to overcome the stress or the drive-shaft/transmission breaks. This is why part time 4WD’s should never select 4WD on paved surfaces.
Constant 4WD’s have a central differential within the transmission to overcome this problem. However once in the dirt a constant four wheel drive can be bogged with only one wheel spinning. This is why they have a central differential lock that stops the action of the center diff and makes it like a part-time four wheel drive in 4WD mode. The center diff lock should never be used on paved roads or non-slip surfaces for the reasons mentioned above.
In reality, a 4WD is only a two wheel drive with one front and one back wheel driving when traction is lost. One wheel on each axle spins while the other receives no drive at all due to the action of the differential. The exception to this is when a limited slip or locking differential is installed. A limited slip diff allows a limited amount of drive to be applied to the stationary wheel before the other wheel on the same axle spins. A locking diff allows no slip at all and both wheels on the same axle turn at the same speed, regardless of the amount of traction.
High/Low Range
To enable a 4WD to travel at lower speeds while traveling on rough terrain it needs lower gear ratios. Not all 4WD’s have low range gearing and this restricts their ability to tackle rough terrain. However 4WD’s that lack low range gearing are generally not built for severe off-road conditions or sometimes have a "crawler" 1st gear to compensate for the lack of low range gearing.
The high range ratios in 4WD mode are the same as the gear ratios in 2WD. When low range 4WD is selected, the gear ratios are approximately half that of high range, although the exact ratio varies for each vehicle manufacturer.
For example this means that if an engine speed of 3000 rpm in high range fourth gear is 65 mph, then in low range at the same engine speed and the same gear, the speed would be around 30 mph.
Some points to note about low range gearing are:
You cannot select low range in 2WD mode in most cases.
You do not have to use low range as soon as you put the vehicle in 4WD, but only if the terrain requires it.
On most vehicles you have to be stationary when changing from high to low range, check your owners manual for your particular vehicle.
A handy hint when reversing with your vehicle while towing is to select low range 4WD to be able to move very slowly without having to slip the clutch. However you can only do this if you have a constant 4WD or your part-time 4WD is fitted with free-wheeling hubs AND they are not locked in, otherwise you will cause transmission windup.
Free Wheeling Hubs
If your vehicle is fitted with free wheeling hubs, you will need to lock them in before selecting 4WD. The free wheeling hub connects the front wheel to the front axle allowing it to be driven when four wheel drive is selected.
Free wheeling hubs are fitted to reduce wear on the front diff and drive shaft, and to (marginally) help improve fuel economy when it is in 2WD. Permanent 4WD's do not have free wheeling hubs as they are always in 4WD and need the front wheels to be permanently connected to the axle.
If you select 4WD without the freewheeling hubs locked in, then you will only be in 2WD, even though the 4WD dash light indicator (if fitted) will show 4WD. Even experienced 4WDrivers make this common mistake of forgetting to lock the freewheeling hubs.
i got it off another posting from another website
Bump: What makes a 4WD a 4WD?
Drivetrain
High/Low Range
Free Wheeling Hubs
TitanRev
8,180
3,678
Still here gavan, yesterday did my 80K major service. Cost me RM1034.70. Which is consider cheap as a lot of things was replace and changed.
I didn't change the 3 belts as they were changed on 46K service so still can less another 8K so will change it on next service.
The 80K major service list is long. All the fluid was reaplce, 2x fuel filter, tune up...etc...etc
gavan
1,408
Shah Alam
wah wah!! eh, did you change your absorbers before? are you using lift up absorbers or used back the stock ones?
TitanRev
8,180
3,678
Happy Chinese New Year
traize
519
5
hey any1 want those heavy duty absorber can sms me i sell, very good i use for off road n even in city driving it is great at high speed ur car wont sway or float as the absorber is anchored firmly to the ground, even u hit pothole u wont feel it is there
Bump: for price click here
gavan
1,408
Shah Alam
wow, i can't wait to see pictures bro... wonder if those abs can give some lift to the ride anot... i need to lift the front abit... its dipping now... =( price is good as well... =)
Bump: wow, i can't wait to see pictures bro... wonder if those abs can give some lift to the ride anot... i need to lift the front abit... its dipping now... =( price is good as well... =)
Just one word.... WOW ! Is Mitsubishi back on track to make us an amazing sport car a bit like in the past with the Twin Turbo ? The Concept-RA certainly looks like an artist’s interpretation of a new Eclipse, although the front and rear fascias also share the new Lancer Evolution design language. But this is no Eclipse - in fact it’s anything but a front-drive petrol car with more show than go. This is a...
