Air fuel ratio, have virbation
clanbuster
55
My car have idling problem every morning.
My gearbox is auto.
The car always have high vibration when the car stop on "D".
But this problem go away when is afternoon or at night.
There is no problem for this until i had install turbo.
Could it be:
1) at idle speed, i believe that turbo is turning and i guess there is extra air entering into engine cause too learn?
2) at idle speed, i believe that the inlet pipe is too long and cause less air, so insufficient air into engine cause vibration?
3) yr comment
I don't have Air fuel ratio gauge. So i not sure what happen to my engine.
unknown1x
369
well you can start helping us understand your car more by
your car model
what mod you have done..
any recent activities that might cause your current problem.
check your gear box.. see anythign wrong with it or not.
studsme
5
Singapore
did you do tunning? how is your air/fuel ratio? on a cold start turbo car tend to have higher a/f ratio to run the engine and rev higher. try to let it warm up to normal driving temp then move off
my 2 cent
correct me if i am wrong
The Marketplace Top Posts
Hello all, I'm currently using a GSR Turbo with TD05H E3 turbo. Using E-Manage blue for tuning and running at 1.1 boost. I'm using E3 fuel injectors 510cc. Blitz boost controller.
I thougt of upgrading to higher topspeed. Curently I'm getting 210kh/h @ 7,000 rpm on stock GSR gear box. What's all the sifu's advice on this? Should I go for E3 gearbox? Or E1..E2 gearbox? Or just chg final gear ratio and add LSD?
What's the recommended boost? If I boost 1.5 bar, should I change the...
