AEM FIC 6 FUEL IGNITION CONTROLLER PIGGYBACK
The AEM F/IC is an economical solution for controlling fuel and ignition on
vehicles that do not require stand-alone engine management, including variable
cam timing engines like VTEC, VVTi and MiVEC.
OVERVIEW
The F/IC gives users with OBD-II race vehicles and non-factory forced
induction systems the ability to retard ignition and deliver accurate amounts
of fuel without the need for outdated FMUs or “boost hiding” controllers. This
system works parallel to the factory ECU preventing tuning limitations due to
complex factory timing patterns. 21x17 maps with configurable load and RPM
breakpoints are easily accessed with the F/IC's Windows-based tuning software.
The F/IC draws power from PC USB interface for quick and easy calibration
changes.
PRECISE FUEL DELIVERY
The F/IC intercepts the signal to the stock injectors, allowing the user to
modify pulse-width by +/-100%. The F/IC is among the only piggy-back systems
that can decrease injector pulse-width, allowing the user to drive larger
aftermarket injectors while still maintaining proper air / fuel ratios. This
powerful system can also tap into the factory injector signal and work
independently to drive up to six (6) additional injectors.
TIMING RETARD CONTROL
The F/IC can retard timing from the factory system based on engine RPM and
load inputs. This is achieved by intercepting and delaying the outputs from
the cam and crank position sensors to the engine- with no adverse affect on
applications equipped with variable cam timing.
SENSOR CALIBRATION & CONTROL
The F/IC can also be used to recalibrate / clamp the MAF sensor, eliminating
common problems with non-boosted factory MAFs. The on-board MAP sensor allows
for proper fueling in boosted conditions.
PAYMENT MENTHOD:
ONLINE TRADING ONLY
ONLINE BANKING (MAYBANK)
WE CAN SHIPPING PENINSULAR & EAST MALAYSIA
FOR MORE INFORMATION ABOUT THIS PRODUCT :
CALL / SMS / WHATSAPP: 018-2764 110
OVERVIEW
changes.
PAYMENT MENTHOD:
ONLINE TRADING ONLY
