A32 rear power window and central lock problem
Ultimate Cefiro
579
5
hi itz me the U/C again...............now v a problem dat read:
the rear power window and central lock, oso rear side is totally out of order....when i 1st bought the car, 2 years bek, the rear power window is still in good condition, after a year so, sometimes it cant be controlled....(sometimes when i unwind the rear window and drive, after dat when i wanna wind it up, itz out of order......then for sumtimes.....it runs........... by the mean while the central lock is totally no problem.....it onli out of order along v the power window, simultaneously......).........i tried to change the wholke set of switch oso kenot, if i wan to unwind the rear window from the main power window control panel(driver side) oso kenot..........if i unlock the driver door's lock, onli the front passenger door was unlock but not the rear doors by right it should be unlocked either..........so i m veli confused v wut is the problem actually?????????? but not the motor anyway coz i tested it b4 v a 12v battery and the motor works........i noe that there is an I/C board in all the switches panel.......so does it matter????? or maybe izzit the wiring????? or the switch???? anyone tried dat b4???????????? SIFU HELP ME~~~~~~~~~~~~~~~~~~:cry_smile: :cry_smile: :cry_smile:
ongteckweng
5,000 RPM
5,806
55
ok...i have this prob when i transplanted the VQ25DE...our a32's power window n central locking r control by a relay or I/C board located @ the back of the switches...i suspect thats the culprit...try getting TC to check on them...
and if its kong, u wont find them in chop shop coz its diff model for jap 2.5 n 3.0...u will need to get them thru TC or other spare parts shop...
weikee
924
15
I got this problem with my B13. and i suspect its the voltage supply low (maybe due to old wires), sometime the voltage will drop till ~11v
Ultimate Cefiro
579
5
ONG: hahqaha i noe about industry electrical but not car....i oso noe using multitester n not volt meter....the traditional tester u noe hoiw ar???? by hand lar....if u shocked dat means got elec. flow klor.......hahahaha
ongteckweng
5,000 RPM
5,806
55
not sure...better ask those who r familiar with car's wiring to do lor...
anyway, i saw ur car today...@ kepong baru's wet market...damn shiny ahh...:p
Ultimate Cefiro
579
5
eh???? ya eh?????? :D few days didnt wash liao wor........dirty like hell......how come i didnt c u????? u spy me again ar????? :P
Ultimate Cefiro
579
5
hahaha luckily i din bump into u lor.......hahahahahaha
if u c a black ceffy in Kepong Baru, u should say " FEILO LAI LIAO!!!!! SIAM A!!!!" :P
dee889
22
Dear All,
Got similar problems but it involved only the central locking. It can lock and unlock by itself and sometimes you can't even lock/unlock using the switch at the door panel. Furthermore, the driver's side is always need to be locked manually. Read some earlier recommendation to check the power supply. Will take that advise and if you guys have any other recommendations, please also share...Thanks in advance!
chteo
176
15
518
Subang
Dear All,
there's a possibility it might be the alarm going haywire, happened to my other car....
Nov 25, 2011
Rawang Selangor
I have experienced both problem not so long ago ..power window due to motor weaken ,change the motor not from Nissan but mod d holder now no more problem..central locking my mechanic change one mechanism the sensor if not mistaken since then no more problem perform well with my new alarm system.
The Marketplace Top Posts
I've never been a believer of camshafts not because I think they're funny, only because I own an auto car. To make it worse - I'm driving a 3-speed auto. So anything that affects my low end is generally a bad thing for me since my gear ratios are ridiculously tall.
What does that mean? It means camshafts are for people who want to improve their mid to highend power. Or so I thought...
