A32 - 3.0v6 engine jerking
ctk22
129
I drove frequently to Pengkalan Hulu, Perak. In case u guy dont know, it further north from Grik, Perak, and just next to Betong Thailand border. I took my A32 thru all those corners high speed, up to 110 or 120, and the car still quite stable although the body tilt quite noticeably. Tires screeching when rolling on road marking paint makes me a bit scared to go step on harder. Perhaps it's due to my Michelin XM1 grip not so good.
Also taken this car up the Jelapang - Kuala Kangsar tunnel winding road, overall very stable and felt well-footed.
sb3
1,141
5,138
Wow , high speed corner @ Grik road, 110-120kph, amazing man! But take it easy on that road bro, safety firstlah.My friend spun 360 deg b4 using that road. Maybe he does not have the skill, hehehe... Anyways good touge!:biggrin:
weikee
924
15
I'll advice not to such driving in such road. my experience are much more painful. not on the same road, but other road with other car.
ctk22
129
thanx for the advice...
actually i'm quite familiar with this road, that's why i dared to go at this speed. I travel almost weekly up and down to KL, that's why the car clocked to 400k km so fast
Anyway, saw another Perak registered 30GV driving more aggressively in this stretch, maybe some mod on the suspension already.
sb3
1,141
5,138
CTK22, you have solve your jerking problem by engine swap, good for you. But has anyone ever solved the jerking problem without engine swap ? No really I mean fixed the jerking problem? Why so many VQs have these problem after certain years of usage? Is that a engine flaw or what. I've notice that even in the states they r having this similiar problem. I don't hear a camry or an accord having such problem (same manufacturing year). I'd reaaly like to find the culprit. Any suggestion?
ctk22
129
no idea what's actually the problem. Maybe due to heat that's causing the decay of sensors' ability? U know, this V engine produce a lot of heat.
weikee
924
15
I mention some of the things you can look at before, maybe you just dig back the history. I solved mine.
Omari
Feb 10, 2013
Bintulu
Hi to all,
I have similar problem on my a32 30. Asked a few friends. One of them open hood, star engine, engage D. He notice slight movement of engine, he said maybe engine mounting koyak. Maybe true as he had same problem on 2 old cars before.
12savefuel
195
75
Guys with reference to the Original jerking problem during idle in D or N problem, if you have tried all the options as previously described in the forum, I suggest to try changing 2 new O2 sensors, as this controls the AF ratio at idle. It feels like a lean misfire stumble rather than rich misfire stumble.
As with reference to detonation, yes the VQ30 does detonate and is intake air temp related. It will detonate from -0.2bar all the way to 0bar with high load on the engine like A/C on and a slope in 2nd, 3rd, 4th gear. It will even detonate starting at -0.3 bar if your EGR system is blocked or faulty. I have tried it and if you disable the EGR system it will detonate at -0.3bar so make sure your whole EGR system is clean and working well.
Hi to all,
You will only have this problem when you engage from N to D or switching between gears. The problem if I understand it right is that in D when idling it will misfire and stumble. Which a broken engine mounting will not solve. If the mounting is broek when moving between the gears you will feel a "klok" feeling. The feeling that other are getting is a stumbling and misfire like when your heart skips a beat. It will idle smooth then miss, then idle smoooth then miss 2 -3 times them smooth again, all while in D but will never stall. The VQ engine should be smooth all the time.
hi guys,
just wanted to see if anyone has used the evo1/2/3 oem absorbers + springs before? im looking to convert my wira GSR back to "comfortable-like-stock standard" cos ive got a baby on the way...been using adjustables for many yrs, and its time to change...
so i've asked around, and got mixed opinions, which got me all confused...i wanna go back to the stock standard comfort level, dont bother about performance anymore...so obviously oem is the way to go...question is, which oem...
