62mm Racing Throttle Body for MMC SOHC
DDT
62mm Racing Throttle Body for MMC SOHC : Proton / Mitsubishi
Designed as a direct replacement for your throttle body, This throttle bodies are all billet aluminum construction and the perfect upgrade to get rid of that tired old throttle body on your car. Instantly increase horsepower and torque by optimizing airflow to your engine.
Available in 62mm Throttle body top part.
Give you:
- Improved throttle response
- Better acceleration
- More high end output
Throttle body bottom part come with brand new halfset ISC servo kit.
Problems with below:
- Engine cold start failure?
- Engine idle stall immediate, after switched on the car Air-cond system?
- Engine rough idling which is suffering the heavy electrical load in car?
By getting this halfset ISC Servo kit for the throttle body as the cheapest way to rescue/ correct your car idling.
Suitable for:
4g13p (1300cc)
4g15p (1500cc)
4g92p (1600cc)
4g93p (1800cc)
4g63p (2000cc)sei
DDT
Give you:
Suitable for:
4g13p (1300cc)
4g15p (1500cc)
4g92p (1600cc)
4g93p (1800cc)
4g63p (2000cc)sei
DDT
Give you:
Suitable for:
4g13p (1300cc)
4g15p (1500cc)
4g92p (1600cc)
4g93p (1800cc)
4g63p (2000cc)sei
*please contact 012-3223583 (Franky Long) for more details.
Whatsapp / call
Thank you.
DDT
Give you:
Suitable for:
4g13p (1300cc)
4g15p (1500cc)
4g92p (1600cc)
4g93p (1800cc)
4g63p (2000cc)sei
Whatsapp / call
Thank you.
DDT
Give you:
Suitable for:
4g13p (1300cc)
4g15p (1500cc)
4g92p (1600cc)
4g93p (1800cc)
4g63p (2000cc)sei
Whatsapp / call
Thank you.
DDT
Give you:
Suitable for:
4g13p (1300cc)
4g15p (1500cc)
4g92p (1600cc)
4g93p (1800cc)
4g63p (2000cc)sei
Whatsapp / call
Thank you.
DDT
Give you:
Suitable for:
4g13p (1300cc)
4g15p (1500cc)
4g92p (1600cc)
4g93p (1800cc)
4g63p (2000cc)sei
Whatsapp / call
Thank you.
DDT
Give you:
Suitable for:
4g13p (1300cc)
4g15p (1500cc)
4g92p (1600cc)
4g93p (1800cc)
4g63p (2000cc)sei
Whatsapp / call
Thank you.
DDT
Give you:
Suitable for:
4g13p (1300cc)
4g15p (1500cc)
4g92p (1600cc)
4g93p (1800cc)
4g63p (2000cc)sei
Whatsapp / call
Thank you.
DDT
Give you:
Suitable for:
4g13p (1300cc)
4g15p (1500cc)
4g92p (1600cc)
4g93p (1800cc)
4g63p (2000cc)sei
Whatsapp / call
Thank you.
DDT
Give you:
Suitable for:
4g13p (1300cc)
4g15p (1500cc)
4g92p (1600cc)
4g93p (1800cc)
4g63p (2000cc)sei
Whatsapp / call
Thank you.
DDT
Give you:
Suitable for:
4g13p (1300cc)
4g15p (1500cc)
4g92p (1600cc)
4g93p (1800cc)
4g63p (2000cc)sei
Whatsapp / call
Thank you.
DDT
Give you:
Suitable for:
4g13p (1300cc)
4g15p (1500cc)
4g92p (1600cc)
4g93p (1800cc)
4g63p (2000cc)sei
Whatsapp / call
Thank you.
DDT
Give you:
Suitable for:
4g13p (1300cc)
4g15p (1500cc)
4g92p (1600cc)
4g93p (1800cc)
4g63p (2000cc)sei
Whatsapp / call
Thank you.
DDT
Give you:
Suitable for:
4g13p (1300cc)
4g15p (1500cc)
4g92p (1600cc)
4g93p (1800cc)
4g63p (2000cc)sei
Whatsapp / call
Thank you.
Hi guys,
Need help and advice on this. My steering shakes excessively when I push my brake pedal especially
when at high speed. I'm driving Evo 8. Some info on my brake system:
I'm using stock brembo calipers, stock rotor, and Project µ front pad 0-600 degreeC.
What should I do? resurface the disc?? check the brake fluid??
Thanks guys
